Teak and Holly Veneer Only? - Page 3 - SailNet Community
post #21 of 25 Old 02-03-2010
Old as Dirt!
svHyLyte's Avatar
FWIW in 1987 I used 5/16" teak and holly veneer plywood to cover the sole in the main cabin of our, then, 1976 Cal 2-29. We made a pattern out of brown butcher paper and laid it out on the back of the plywood. After shaping, we then used a mat-knife to score the back side at 2" intervals both fore'n aft and transversely. This allowed the ply to conform to the curvature of the sole without splitting. The material was temporarily held in place with #10 wood screws while we installed #10 flacehead wood screw, counter-sunk so they could be covered with plugs. The rows of screws were approximately 18" apart. We framed around the openings to the bilge, and the covers with 1" by 5/16" teak strips with mitered corners. The plugs were shaved flat with a very sharp small hand plane. The whole surface was roughened with 220 grit paper and covered with 9-10 coats of Minwax Helmsman Semi-gloss urathane and a final coat of the mMinwax Urethane made for hardwood floors which is much more durable. The most difficult part of the job was sculpting 1"x2" moldings around the edges which took a long time as the teak doesn't bend too readily and that was before I knew the trick of making a steam box our of cardboard, foil and foam.
It was a job but the end result was very pleasing. By keeping the deck clean and free of sand, and periodicly scuffing it up and applying a new coat of clear floor vurathane, it looked as new we we sold the boat in 2003.
Below you can see a bit of the sole and the decking on the step at the foot of the companionway (that was not fastened down but served double duty as a table-top in the cockpit).
svHyLyte is offline
post #22 of 25 Old 02-03-2010
Old as Dirt!
svHyLyte's Avatar
Follow-Up
As a follow-up to my post above. Had teak and holly inyl flooring been available at the time, I surely would have used it. See Lonseal Teak-Holly Flooring, 6'wide x any length:World Panel Products Inc
svHyLyte is offline
post #23 of 25 Old 02-19-2010
TAK
TAK's Avatar
I went on a Hylas a couple of years ago at the Annapolis Boat Show that had a bamboo sole with teak inlay. I thought it was stunning. I am contemplating something like that using regular hard wood bamboo flooring over a 1/4 inch ply.
s/v Mahalo
Caliber #4065
ACM - Eastport MD
TAK is offline
post #24 of 25 Old 02-19-2010
Send a message via Skype™ to TomRay
Originally Posted by cormeum View Post
The Holly originally was ridged to provide some grip. At least that's what i've been told.
Wow, I'm a traditionalist! I made my sole teak and sandy recently.
TomRay is offline
post #25 of 25 Old 02-19-2010
mitiempo's Avatar
If you're trying to make it non-skid use walnut shells. Works well and nowhere as rough as sand. West Marine sells ground walnut shells.
Brian
mitiempo is offline
Advice refinishing teak and holly sole mcagney Gear & Maintenance 21 03-10-2015 09:08 PM
Teak woodwork TXS-ALAMO Gear & Maintenance 1 02-12-2013 09:38 PM
Holly grail for new teak! wakesurfboy Gear & Maintenance 57 10-20-2009 09:39 PM
teak sole, the real stuff feetup Gear & Maintenance 2 10-26-2006 05:31 PM
Replacement Teak and Holly Sole (C&C 37) thomsonjd Gear & Maintenance 2 11-29-2001 06:17 PM
