01-28-2010
Cal 9.2 SilverSwan
This is a no brainer if I checked out the proper Raymarine manual and you are willing to use instruments. The back side of the radar unit has a 3 pin curved seatalk connector. I also have this on a 630 chartplotter. I have all of my ST60 instruments daisy chained and connected to this port. I can go into a custom display setting and display any of my seatalk data in a small box on the screen. You will need the ST displays to convert the sensor outputs from pulses to seatalk format. You should be able to find the ST50 instruments on the cheep, I have found them under $100 each..... they work also... to go with NMEA sensors only, please post what ends up working for the rest of us to learn from. THANKS
Cal 9.2 #19 SilverSwan
