01-27-2010
Tartan 27' owner
1 - What kind make and model engine is it? Gas or diesel?
2 - What kind of transmission is it (V-drive, direct, other)?
3 - What kind of boat is it installed in? When was the motor installed (orginal or re-power)?
4 - Does your transmission have a separate oil lube from the motor and is it full?
5 - Odd noises out of your engine/transmission indicate that there is something you need to take care of. How long have you owned this boat and what do you know about the engine/tranny?
The more information you give, the more someone can help you.
Some engines are just plain noisy but metal on metal noises are not good.
A picture or two might help those that have been there before you.
Good luck.
Reason: edit
