Old 01-29-2010
Irrationally Exuberant
arf145 is on a distinguished road
Connector for running a wire through the deck
I'm running a cable, probably flat boat wire (14AWG/2), from a solar panel that's off the stern rail and need to go through the upper transom right below the hull/deck joint. I see there are through-deck connectors that will keep things sealed up and make it easy to disconnect. Any recommendations on the best one for the job?
BTW, the reason I'm probably not going through the deck is that there's little of it back there except a 2" lip that really isn't flat and serves as a water trough.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 01-29-2010
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
We used one of these to run our LPG pipe through the deck. Been in for four or five years now and no sign of any leaks. Doesn't seem to have deterioated in the sun either.
NEWMAR CCX-R WATERPROOF FITTING 1.38" MAX DIAMETER Shop.Sailnet.com - sailing resources, shopping, sail, blogs
Old 01-29-2010
kaluvic's Avatar
kaluvic is on a distinguished road
Those connectors don't work so well with the geometry of the flat wire.
If you must use that wire then maybe a goose neck with "monkey ****" packed around it.
James S
S/V Arctic Lady
Old 01-29-2010
christyleigh's Avatar
christyleigh is on a distinguished road
A few yeas ago I used a very similar item to the one TDW showed but the difference was the piece of rubber in the middle was Not Pre-cut so you could make your own drilled holes and slits for multiple wires or off shaped ones. Cable Clam keeps coming to mind but that could very well be wrong. I it got at either W.M. or Defender.
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
Old 01-29-2010
mitiempo's Avatar
Blue Seas makes cable glands as well.
Brian
Old 01-29-2010
tdw, those look good, but I'm more interested in one that has an unpluggable electrical connector, not just a sea gland.
arf145
1987 Pearson 28-2
Chesapeake Bay
Old 01-29-2010
JSL3's Avatar
<----- thinking of this
JSL3 is on a distinguished road
how about this link
just saw you want to use flat wire, if not, follow the link
~Jim
Ramble On
1986 Pearson 28-2
Old 01-29-2010
mike dryver is on a distinguished road
you can get1 to 4 pole connectors like what yuo want at Defender and Hamilton Marine in Me. i have them on my boat for connecting the auto pilot power when i use it . they screw on caps with chains attached. i have others for the radar power plug and those have o rings (which are greased)on the male end and the cap just pushes on. these last ones i don't see in stores anymore but the first are still avail.
Old 01-29-2010
JSL, that one looks interesting, though from the picture I can't quite make out how it sticks up 2 3/8" and which part is the plug. I'm not married to the flat cable, and in fact if it's going to an exterior connector, I guess it won't matter--I can do the flat from the inside part.
Mike, I'll check the Hamilton catalog for those. I have actually done my online and catalog search, and saw many of these options, but am missing the real world experience with them. I hate to buy without some idea of what I'm getting first. Is this one of the ones you are talking about from Hamilton:
arf145
1987 Pearson 28-2
Chesapeake Bay
Keeping Wiring Woes at Bay Chris Brignoli Gear and Maintenance Articles 0 01-26-2004 07:00 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
Electrical Work Rules Don Casey Gear and Maintenance Articles 0 07-16-2000 08:00 PM
