-   -   Any way to lighten teak that has been stained dark? (http://www.sailnet.com/forums/gear-maintenance/61668-any-way-lighten-teak-has-been-stained-dark.html)
TakeFive 01-30-2010 08:26 PM
Today I visited a '98 Catalina that I am considering purchasing. This vintage of boat is shipped from the factory with a lighter orangish-color interior teak finish that I really like. Unfortunately, one of the prior owners appears to have been very meticulous about refinishing the wood. Although the wood was nicely varnished, it looks like he also refinished with a darker stain.
There is not a whole lot of teak in this boat, so re-refinishing would not be as huge a project as with other boats. Would it be possible to strip off the varnish and somehow bleach the darker stain out, then go back in and redo with a lighter stain and varnish? Could such a bleaching product actually lighten the dark grain lines, which seem to absorb the stain so strongly? If so, could you recommend products for stripping and bleaching the wood?
mitiempo 01-30-2010 08:58 PM
Normally wood is bleached lighter with oxalic acid, available at at some paint and hardware stores. It is also in many of the teak cleaning products available in marine stores. I can't imagine why anyone would stain teak as it looks great the way it is. I've always picked wood for its looks without stain rather than trying to make it look different or like another wood. If you can remove the varnish totally it shouldn't be a problem. The teak should look great with plain varnish or oil as it is a beautiful wood.
CharlieCobra 01-30-2010 09:07 PM
TeKa A & B...
MJBrown 01-31-2010 12:41 PM
If I read your thread correctly you're referring to the interior teak, not the cockpit. If that's the case be careful what product you use as some of them are rather toxic. TEKA A-B is one them. Oxcylic acid to a lesser extent. BTW household bleach mixed with water at a 1:3 ration cleans teak but not sure it would lighten it consistently. Good luck.
lancelot9898 01-31-2010 05:20 PM
I've had good luck with sanding with an orbital sander.
mitiempo 01-31-2010 05:28 PM
On surfaces where the veneer is 1/16" or less sanding can be a mistake if you're not very careful.
mike dryver 01-31-2010 06:16 PM
why would some one have to refinish a ten yr old boat on the inside? since you don't know who did this see if you can track down the owner who did this and find out if he used a water based stain. you should be able to get it off with water and soap and scotch-brite pad/sponges. if it is oil based leave it alone because the out come will never be right enough to restain to original.
Pub911 01-31-2010 09:49 PM
If you can get down to bare wood, I have had very good luck with a two part system called "Snappy Teak-Nu". URL here: Snappy Teak-Nu: 2-part teak cleaning system
Read instructions well and be careful not to let product get on other painted or sensitive surfaces, as there is a mild varnish remover in it that will lift paint.
QuickMick 02-01-2010 01:44 PM
depending on the location (ie interior/exterior) ive found the typical PO has been lazy in many cases and simply stained over what needed actual TLC. If in the cockpit, or the top of the stern rail i would seriously consider sanding until ive found good wood.... that stinkin mildew finds every crevice (except the those in our pants i hope) and needs to be eraditcated..... then finish as desired.
