Converting old stuff to NMEA - SailNet Community
 1Likes
post #1 of 19 Old 01-31-2010 Thread Starter
Can I make my ancient speed (SciTex) and Depth (DMI) sending units talk to my NMEA compatible devices? Are these outdated units really dead for good?
C'mon, we're sailors aren't we? Isn't there a cheep-o way to make this work?
Pub911 is offline
post #2 of 19 Old 02-01-2010
No, probably not.
sailingdog is offline
post #3 of 19 Old 02-01-2010
"Isn't there a cheep-o way to make this work?"
Sure there is. A chip log and a lead line, two pieces of string and you're in business. Whoever swings them can then convert them to NMEA on the fly.
Electronic conversion? No, there's a time to just give it up and walk away.
hellosailor is offline
post #4 of 19 Old 02-02-2010
Cal 9.2 SilverSwan
roline's Avatar
REAL Cheep way, no, but there is a way. I made an adapter board ($90) for the DMI speed transducer to talk to the ST60 speed display($80 on ebay), Raymarine makes the Seatalk to NMEA converter E85001 ($160 new).
I believe the DMI depth puck is a 200khz unit, if it is it can hook directly to a Raymarine ST60 depth instrument, I've seen them on Ebay for around $150 display only.
Once you have the converter, you can also hook it to a laptop for navigation software......You can do it for under $500 which is cheep when you consider the list prices on new ST60 instruments.....
Raymarine (Airmar) speed paddle wheel sensors have a hall effect sensor and 0 to 12 volt output. ( 12 volt power, signal, gnd) The older DMI have a 2 wire low level signal requiring excitation on the signal wire.
Did not know about the actisense NMEA converter, looks like a great product!
Cal 9.2 #19 SilverSwan
roline is offline
post #5 of 19 Old 02-02-2010 Thread Starter
I read this and went...
YAY!!!!.....ummm, awwwwwe nuts.
Ok. I guess I have to face into reality. In a similar post I asked if anyone had recommendations / experience on "active" Depth/Speed/Temp transducers or so-called "tri-"ducers when they do a hat-trick on D/S/T.
Airmar has a line running about $350. Anyone have experience with these or know of a better or cheaper unit?
Does Raymarine make a tri-ducer unit that talks SeaTalk? I can go that route as well if need be.
Thanks all.
Pub911
Pub911 is offline
post #6 of 19 Old 02-03-2010
Umm... Raymarine actually doesn't make transducers...they use AIRMAR transducers, so if Airmar makes it, Raymarine resells it...
Thanks all.
Pub911
post #7 of 19 Old 02-03-2010 Thread Starter
Thanks S-dog. Appreciate the OEM-insight.
P
Pub911 is offline
post #8 of 19 Old 02-05-2010
ActisenseTechSupport's Avatar
Actisense DST-2
We have a product which will convert old depth speed and temp transducers into NMEA 0183 data, the DST-2
Depth
connects to a standard piezoelectric depth sounder crystal element using a 3-wire interface.
Speed connects to a standard 'paddle-wheel' hall-effect trancducer using a 3-wire interface.
Temp connects to a standard thermistor transducer using a 2-wire interface.
For example the DST-2 works with Airmar's DST800's.
ActisenseTechSupport is offline
post #9 of 19 Old 02-05-2010
Please read and follow the Special Interest disclosure thread in the Boat Buying forum.
Depth
post #10 of 19 Old 02-05-2010
Tinley Electronics also makes a transducer/paddle wheel - nmea converter. There are some differences in features and price with the Actisense product. Tinley Marine Electronics.
I don't have any first-hand experience with either of these devices, but will probably install one in the next few months.
Pearson 33-2
Western Long Island Sound
davester is offline
windsensor for rotating mast, microPC needed for NMEA correction blubaju Gear & Maintenance 6 03-09-2015 11:28 PM
ST60 Multi NMEA Interface dave8976 Gear & Maintenance 20 07-23-2010 04:14 PM
What happens to all the stuff from boats that are scrapped / totaled? T37Chef General Discussion (sailing related) 2 10-21-2006 10:42 PM
NMEA stds and Magellan 315 GPS mikehoyt Gear & Maintenance 3 06-05-2002 05:03 AM
The NMEA 0183 Data Sentence Jim Sexton Gear and Maintenance Articles 0 10-17-1999 08:00 PM
