02-01-2010
I have made a few. For some small boats, you can just use a piece of stainless plate. The piece that I got was a cutoff from a large construction project which I got for free. Some production centerboards were steel plate which you can buy as well. If you are working with steel, you will need a way to drill it and cut it.
I have also made a wooden centerboard and put weights in lower end. If you can get a large enough piece of wood, you can make a solid board, otherwise, you have to put a couple of boards end on. When doing that, you can tie them together with a couple of really long bolts drilled through them.
I would think that building a cored fiberglass board with a cast weight in one end shouldn't be too hard either but I have never done it.
What are the dimensions of the board? That will help to determine what makes sense for material and construction method. For example, if the trunk is really narrow, a steel sheet makes sense but if it is really wide, a wood or fiberglass lamination would make sense.
