02-01-2010
It sounds like you have the auto and manual wires reversed at the switch. To confirm this put it in manual and make sure it is in water. There is a delay so wait a bit and if it pumps it is wired backwards. If it doesn't it could be a faulty switch. The ground is good or it wouldn't run at all. If it is wired backwards what you describe would occur. Also make sure it is level the long ways as shown in the manual and below.
Brian
