02-03-2010
West Systems has done extensive research into this, and published papers on it... Gelcoat, as a protective cosmetic finish, does stick well enough to epoxy resin repairs, provided the epoxy surface is properly cleaned and prepped. Epoxy resin will stick to the existing fiberglass and gelcoat far better than polyester resin...
Originally Posted by doctorcam
I don't think - others will probably know more about this - that gelcoat will bond well to epoxy. The opposite is true. Better to fill with polyester resin, and put gelcoat over the top of that.
Good luck
