Old 02-06-2010
Kids4sail is on a distinguished road
Deck screws stripped.
I have a Hunter 23 and was removing teak to refinish. Some of the holes in the deck are stripped. I remember somebody mentioning how to fix this by filling the holes and redrilling. Does this work? What can I use to fill the holes outside of west epoxy?
Thanks
Kris
H23
Sail it like you stole it!
Old 02-06-2010
System 3, MAS, Progressive Epoxy Polymers all make a decent epoxy that you could use. System 3 has some that come in a caulk-type tube that use a mixing nozzle and come pre-thickened.
You could also use MarineTex marine epoxy two-part putty.
Old 02-06-2010
BigZ is on a distinguished road
Not sure if you can tap into cured epoxy, either with wood screws or machine screws. Most info I've seen about epoxies and fasteners has to do with embedding a nut or stud in the epoxy then fastening to that.
You could overdrill the existing hole and glue a dowel in place. Saw flush and screw into the new wood.
Old 02-06-2010
nickmerc's Avatar
nickmerc is on a distinguished road
You can tap into thickened epoxy, just make sure your pilot hole is not too small or you will not be able to do it.
________
5 stage grinder
Old 10-17-2010
mroman33711 is on a distinguished road
Maybe i'm mistaken, but couldn't you just use a screw that is just a little larger than the old screws? atleast that's what i do whenever i strip a screw
Deck Washdown Systems Sue & Larry Cruising Articles 0 02-23-2004 07:00 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
