02-06-2010
Not a big deal to repair, especially if you have good access to both sides. You'll want to grind a 12:1 bevel on both sides and repair it from both sides, as this is a stronger repair than if you just do it from one side. I'd also highly recommend using epoxy resin, as it has greater secondary (adhesive) bonding strength than polyester or vinylester resin.
