02-08-2010
Unless you have a really massive solar array, it won't really do much for a hot water heater. Water just takes too much energy to heat that way. A better way to heat hot water is to setup a small solar water heater on the cabin top. If you've ever used a solar-shower setup, you realize how hot water can get with solar heat....
