Holes in my cabin liner - SailNet Community
Blogs
Old 02-09-2010
Catalina 25
jjrunning is on a distinguished road
We just got a 1982 Catalina 25 swing keel on a trailer and we're going through it, getting it ready for the summer. I found these two holes in the v-berth that have dirty looking water coming out of them... I'll try to attach the picture I took. They appear to be old screw holes that a previous owner had something attached to.
Does anyone know what's going on here? What can I do about it? Thanks!
Old 02-09-2010
tommays's Avatar
tommays is on a distinguished road
Well
Water got someplace it should not have and in a very "general way" when it comes out brown it tends to involve and issue with dammage of something you cant see right now
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 02-09-2010
Catalina 25
Should I sand/grind it out and see what I find?
Old 02-09-2010
DwayneSpeer's Avatar
Old Fart
DwayneSpeer is on a distinguished road
What's your philosophy?
Are you ready to go all the way?
Do you want a pristine boat?
Can you live with the knowledge that there may be damage in there?
Almost all boats that are more than a couple of years old have had water seep in somewhere and do some potential damage but almost all owners just live with it and go on sailing.
Try to spend your time finding out where the water got in and fix that. Otherwise just clean up the brown mess and watch it for further water ingress.
Hey, can one of you guys pass me a crab?
Old 02-09-2010
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Weeping water stains from the laminate.
The screw holes are not in a 'liner material' of some sort are they? If there is no liner then there is water in the laminate material that makes up your hull. If there is a liner then you should remove the liner to see what is going on behind the liner.
The first and easiest thing to do is to clean off the existing stains and not plug the holes but monitor the holes for more weeping. Plug the holes only when you are certain that there is no more moisture getting in there.
You should also test the hull in that area on the outside for any signs of softness. You can tap the hull and listen for different sounds that may indicate more water or even separation of the laminate material. I would also check all the deck fittings in that area for proper bedding compound beneath them. Is there a chain plate near that spot? Are there any small blisters on the bottom of the hull beneath that area?
If there are no signs of softness in the material around the weeping screw holes then you just need to try to stop the water intrusion from continuing. I hope the damage is minimal for your sake but it should not stop you from enjoying your boat.
Old 02-09-2010
HARDWORK is on a distinguished road
Check all your deck fittings, and rebed if they even look suspect. There is a leak somewhere above. I had a Catalina 30 that took 2years to find a stantion that was leaking. After you fix your leak and get no more water sepage, then you can repair the screw hole. Just keep a sponge handy to clean up the brown water and go sailing.
Old 02-09-2010
Catalina 25
Thanks so much for all of the responses. I'll monitor it for a while and see what happens. There is a lifeline stanchion right in that area above so I'll pull that up and take a look. I'll check for soft spots tomorrow when the snow has stopped and I can get in.
I can definitely live with it. I realize that it's a 1982 boat so I expect things to have their problems. Good to know that it shouldn't be a big issue though.
Old 02-09-2010
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
JJ--For what it's worth it would be helpful to have a better idea of just where your seepage is (hopefully there is not a holding tank or waste line on the opposit sied of the panel!). In any case, there should not be water, or any other fluid, draining from a hole in a hull liner and I would be concerned about the matter. If it is water; and, you are in a particularly cold climate, freezing could cause rather a lot of damage.
Old 02-10-2010
Gladrags1's Avatar
Sailor
Gladrags1 is on a distinguished road
JJ, you got a lot of good suggestions! Catalina uses hull liners so you don't have a problem with the hull. That's good. It looks like it is at the bow under the deck. You mentioned a stantion which is likely the cause. Another possibility is that the bow pulpit (if you have one) is needing rebedding. The brown color is likely from wood backing or wood coring (Catalina used plywood coring, I believe, in their smaller, older boats). Check for softness right around the base of the stantion and the pulpit. You can also test (when it gets warmer) for water leakage by spraying a hose at the suspect fitting while isolating it from other fittings. Use a lot of force and a lot of water. Have someone below decks to see if you get a drip. Start at the fitting closest and downhill from other fittings. Then work your way uphill until you see a leak. If you don't get anything, spray water upwards at the bottom of the rubrail. That's the hull-deck joint. The rubrail is installed on top of the joint which is like a shoebox top with bolts going through the rubrail, deck and hull holding everything together. It is not likely that this is the cause but... If it is, you definately need to rebed that puppy! If you get leaks at stantions, etc, it would be good to rebed them all isnce they are all the same age. Another possible area is the mast-step. I don't know how likeli tyhis is because it may be uphill from where the area is but it is a place to test. In general, this is a likely cause of problems since there are many holes for screws and wires inside and there is a lot of downward pressure from the mast at this point. Look carefully to see if the deck is perfectly flat here. Any depression means that there is a leak and you should have it fixed with new wood backing / support. This is not an area to treat flippantly as there are a lot of pressures here.
Good luck, get it done and go sailing!
Tod
Old 02-10-2010
Gladrags1's Avatar
Sailor
No, don't sand / grind it out. Investigate where the water is coming from then fix the hole.
Tod
Drilling and Filling Holes in Your Boat Sue & Larry Gear and Maintenance Articles 0 03-11-2003 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
