02-11-2010
Hey Christine—
What kind of boat are you going to be using the hardware on? I am guessing that you own a Sparrow 16 pocket cruiser.
I would be a bit hesitant to use their gear, especially since the hardware doesn't give any specifications about materials used or safe working loads. Also, they don't mention what kind of bearings, if any, they use in their camcleats.
I would stick with a name brand on this—Harken, Schaefer, etc. For instance, you can get the Schaefer cam cleats for $16.55. They have a safe working load of 300 lbs...and aluminum cams and use ball bearings to ensure smooth movement.
