02-11-2010
The best material for most smaller boats is plexiglas or cast acrylic. It has better UV tolerance than Polycarbonate and doesn't have some of the negative physical characteristics of Polycarbonate. Tempered glass is a great material, but not really appropriate, since a single, relatively minor impact can cause the glazing to shatter. Untempered glass is really foolish. Laminated tempered glass is a good choice but very, very expensive.
The best bedding material for an acrylic port that is not mechanically fastened to the hull using a frame or through-bolted is using an appropriate sealant like Dow 795 Silicone, which is purpose designed for this application. Butyl tape will work well for mechanically fastened ports.
