Old 02-12-2010
Perithead's Avatar
Montgomery 17
Perithead is on a distinguished road
Sailboat Trailer Parts question
I am bringing back an old sailboat trailer and I am buying a new coupling (the part that attatches the trailer to the ball) and a new jack. Their are many different parts to choose from that range from different capacity levels and I am not sure about the capacities of my trailer and boat.
The boat is a South Coast 22 with a displacement of 1800 lbs, so probably 2000 lbs to be safe.
I can get a toungue coupling that is rated for 3500 lbs or 5000 lbs.
I can get a winch rated for 1600 or 1800 lbs.
And a jack for around 1200 or 1500 lbs.
If these are to much or to little, I can get different ones, these are just what I guessed may work.
Does anyone have a good idea of what I should go with. I don't want to spend to much that is why I would like to know what would be safe.
Thanks everyone!
Small is beautiful, simple, cheap, and easy......
Visit my website
! Lots of useful info and sailing videos.
Old 02-12-2010
tommays's Avatar
If your not dealing with a brake type coupling i dont think there will be much difference in the parts prices
The real issue will be if the bigger part will fit well on the trailer as there is allready a substantial saftey margin in the parts if your buying name brands
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 02-12-2010
Perithead's Avatar
Montgomery 17
There are no brakes on the trailer, it is a simple single axle trailer.
I am sure that the coupling will fit on the toungue of the trailer, it is made of 2" square tubing and the coupling is designed to fit that exactly.
Visit my website
Old 02-12-2010
If you figure the boat at 2000 lbs. and the trailer at say another 800... you're up in the area where brakes, at least surge brakes, might be a good idea.
Old 02-12-2010
klem is on a distinguished road
Ignoring the issue of whether you should have brakes or not, you will need a coupler and ball that are 2" to be legal. I would guess that your total towing weight could often be around 3000lbs due to the weight of the trailer and the stuff that will be on the boat. Figure 10-15% tongue weight which is 300-500lbs. It looks to me like all of the products you have listed should be strong enough for the task. I tend to like to overbuild certain parts of trailers like the jack (I have bent a few) and it won't hurt you to do that.
Trailer Sailing Bruce Caldwell Learning to Sail Articles 0 03-21-2004 07:00 PM
Seeking sailboat trailer RogerLS General Discussion (sailing related) 0 10-29-2002 12:43 PM
