Filling in holes in the deck - Page 3 - SailNet Community
post #21 of 29 Old 03-17-2010
Seńor Member
PorFin's Avatar
Originally Posted by dave6330 View Post
OK - so I'm going to display my ignorance again...pre-drill and de-core???
Here's the thread you want to read:
Sealing Deck Penetrations, courtesy Maine Sail -- one of one of the best "go-to" guys on this (and many other) forums.
PorFin is offline
post #22 of 29 Old 03-18-2010 Thread Starter
A really GREAT read!!!! Thanks much to both Sailingfool and Porfin for keeping me from doing something very slipshod (the direction I WAS going).
Once again, Sailnet keeps me on the straight and narrow.
V/R
Dave
[/SIGPIC]Dave
Sailing out of Seward, Alaska
"Fight the good fight, holding on to faith and a good conscience. Some have rejected these and so have shipwrecked thier faith"
dave6330 is offline
post #23 of 29 Old 03-18-2010
btw,mentioned this back in post #4.
sailingdog is offline
post #24 of 29 Old 03-19-2010 Thread Starter
Noted. I guess I was just a little slow on the uptake.
Another question (I have a million of 'em): If I buy a few extra feet of electic wire, is there any downside to simply coiling the excess up near one of the circuit nodes (breaker switch, contactor or in the bow under the winch itself) instead of cutting to length?
I'm certainly not a physicist but something rings a bell in the back of my brain about current running thru coiled line generating heat and a magnetic field.
V/R
Dave
[/SIGPIC]Dave
dave6330 is offline
post #25 of 29 Old 03-19-2010
The longer the wire, the greater the voltage drop and resistance it creates. Ideally, you really want the wire to be the length of the run plus maybe two feet on either end, incase you need to move something, or disconnect/reconnect something. Having a little slack on each end often means you don't have to re-run the wire in the case of upgrading. You also should have enough slack so that you can setup drip loops on any wires that pass through the cabintop, deck or into lockers where water is an issue. .
post #26 of 29 Old 03-19-2010
Hole question and butyl tape
What is the butyl tape used for? How is it used?
TortugasLane is offline
post #27 of 29 Old 03-19-2010
Butyl tape is a very inexpensive and useful sealant on boats. It can be used for all sorts of deck hardware.
post #28 of 29 Old 03-19-2010 Thread Starter
Thanks (again). I'm sure that as this project moves forward, I'll have a few more questions crop up.
V/R
Dave
[/SIGPIC]Dave
dave6330 is offline
post #29 of 29 Old 03-20-2010
STARBOARD!!
KeelHaulin's Avatar
Make sure you use heavy gauge wire (like the size of battery cable) and have good watertight seals on the lugs (adhesive lined heat-shrink) so the wire does not corrode from exposure to moisture. I would not coil the excess wire as you suggested; better to cut to the correct length and then connect the lugs and seal.
KeelHaulin is offline
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
Drilling and Filling Holes in Your Boat Sue & Larry Gear and Maintenance Articles 0 03-11-2003 08:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 09:00 PM
