Old 02-13-2010
Two many boats!
degreeoff is on a distinguished road
plumbing with Seatech?
Hello,
I have bought a whole lot of tubing to redo all the H20 lines in my Catalina 30, well turns out its all hard wall hard to work with stuff that requires special fittings. My question is of the durability of this system. Do you like it and should I keep it or return it?
thanks
Josh
I love to sail, coming from a Swordboat capt's loin one would think I'd of caught the bug long before now! Oh well, this ones for you Bisque...(My Father may he RIP)
Now If I could only stay away from working on the damn things I could sail more!
Current boat...
-1985 c-30 TR DONE!! after two new engines and too much labor she floats sails and steams....
Old 02-13-2010
Maine Sail's Avatar
Seatech is nothing more than re-branded PEX tubing for domestic water. Unfortunately much of it is metric to force you to buy their fittings.
The best thing you can do is to find a local P&H wholesaler who sells domestic PEX tubing and fittings. Use 3/8" not the 1/2" stuff and it will bend and flex considerably easier and route through the boat easier too. Another good thing to do is buy red tube for hot and blue for cold.
Watts and others make quick connect fittings in brass and plastic. You can also buy a crimp tool and do it that way but the quick connects are very, very reliable and can be taken apart if necessary where the crimps can not.
PEX is excellent stuff but the 1/2" in a boat is not necessary for flow at 40 PSI and to hard to route and run compared to the 3/8". The only benefit to 1/2" is that you can buy the fittings and tubing everywhere, including Lowes & Home Depot but 3/8" will usually only be stocked by a P&H wholesaler. Most all P&H wholesalers do cash/retail sales these days.
______
-Maine Sail / CS-36T
Plumbing and Electrical Diagrams TXS-ALAMO Gear & Maintenance 0 01-27-2007 04:14 PM
vacuum break in head plumbing Artwerke Gear & Maintenance 3 01-18-2006 02:13 AM
Boat Plumbing Inspection Tom Wood Buying a Boat Articles 0 02-17-2004 07:00 PM
Boat Plumbing Inspection Tom Wood Gear and Maintenance Articles 0 02-17-2004 07:00 PM
Marine Plumbing Standards tarmand General Discussion (sailing related) 5 10-22-2003 09:36 PM
