Old 02-14-2010
Tanley's Avatar
Tanley is on a distinguished road
New cutlass bearing and shaft movement
With a brand new cutlass bearing, should there be slight movement of the shaft within the bearing or should it be completely tight?
Old 02-14-2010
amarinesurveyor is on a distinguished road
I should be tight if it's the correct size for the shaft.
Brian
Old 02-14-2010
Maine Sail's Avatar
Should be no slop.
______
-Maine Sail / CS-36T
Old 02-14-2010
Pub911 is on a distinguished road
Agree with above, and a brand new one should also dampen the free spin of the prop a bit....like you shouldn't be able to get more than a full turn of of it with a good effort by hand (tranny in nutral, obviously)
Old 02-14-2010
eMKay's Avatar
eMKay is on a distinguished road
How much slop is too much? Wondering if I should replace mine now.
Siren 17 #1094 "Minuet" (first boat)
O'day 192 #488 "Aria" (second boat)
Hobie Wave #2697 (current boat)
Hunter 27 #716 "Revival" (current boat)
Old 02-14-2010
There's probably a standard/spec to it...i'm not a certified engineer. I'm a practical sailor...ahem.
But if your prop shaft is wobbling between the bearing and the tranny, or it's making a sound like it's knocking inside the shaft log, one reason may be the bearing.
Personally, it's a cheap part. If you see a gap between the shaft and the rubber fins of the bearing, I'd change it.
Doing so is easy if you know a few tricks. With a little ingenuity, a piece of threaded rod, some appropriately sized washes and socket(from a socket wrench set) you can make a puller that will suck it straight out of your shaft log.
I realize that leaves some details on the table. Write back if you want more info.
Old 02-14-2010
eMKay's Avatar
I'll be removing the shaft since I want to redo the seal anyway, making it easy.
Old 02-15-2010
Tanley's Avatar
It's probably moving 1/16th total (1/32 on each side). Kind of upset as we had the yard install it and there are a couple of other projects we still need done before launch. I want it right but don't want to piss off the yard.
Old 02-15-2010
tommays's Avatar
How much wear is in your prop shaft ?
If there is some it should have been brought to your attention BUT my not have been
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 02-15-2010
Bazzer is on a distinguished road
Size Matters
Remember the Cutlass Bearing is water lubed, so to tight a fit will result in overheating and a burning bearing. I would check the size of the shaft with a micrometer if you have it out and the Cutlass bearing, I am guessing but the bearing should be no more larger than a thou or two than the shaft. If I had the boat out and could feel any "play" I would be inclined to change the bearing........
Baz
removing rusty coupler set screws victoria28 Gear & Maintenance 22 01-29-2010 12:35 AM
Cutlass Bearing Replacement, 1985 Najad 343 kc_cmc Gear & Maintenance 2 12-07-2004 02:15 PM
Repairing Cutlass Bearings Mark Matthews Gear and Maintenance Articles 0 05-07-2002 08:00 PM
Installing a Cutlass Bearing Mark Matthews Gear and Maintenance Articles 0 04-26-2002 08:00 PM
Cutlass Bearing Query SailNet Gear and Maintenance Articles 0 06-06-2001 08:00 PM
