02-14-2010
If you varnish over the wood, ANY spar varnish should work. I did this to my teak interior a few yrs back. I used "Top Secret" which is a lighter varnish. Some have some yellow in them, and do not do some woods justice IMHO. Some of them that are a bit yellow, do do other woods fine. I did a quick sand down with a foam back 200-300 grit on wood that was permanent to the hull, the rest that I could remove, I brought home and sanded a bit more with a disk sander, then applied varnish in the garage, took back and installed.
I used a cloth, and did 3-5 coats. This looked better IMHO for my application than a foam or typical brush finish.
I' recalling a few Good Old boat articles from the past that bestowed good things about all varieties of varnish tho. Same with some other rags. Woodenboat does a pretty good varnish finsh article upon occasion too.
Marty
She drives me boat,
I drives me dinghy!
