Old 02-14-2010
dillybar is on a distinguished road
Water pump breaker blows
Took the boat to False creek for the Olympics this weekend and the fresh water pump breaker tripped on us a few times. I've never had that happen in this or any other boat - any thoughts? (its a '98 Bene 461 and it only seems to happen when someone is in the shower completely lathered up)
Old 02-15-2010
mitiempo's Avatar
Could be the wire is shorted somewhere between the breaker and the pump. Or the pump could have an issue. Does the pump seem to be working properly. If the pump is stalled for some reason, like a clog, the breaker could go. If you have a multimeter check for continuity between the positive after the breaker and ground. If it shows continuity there is a short.
Brian
Old 02-15-2010
DelmarRey's Avatar
DelmarRey is on a distinguished road
And check connections also. An arcing connection will cause over heating/resistance.
Old 02-16-2010
Thanks much for the input guys. I replaced the pump this past summer and as I recall the displacement of the the new one was around 10% more. I will go down to the boat this weekend with a meter and get to the bottom of it.
Old 02-16-2010
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Presumably you also have at least one filter in your line. If so, check to ensure that the element is clean and not in need of replacement. Our dock-side neighbor had a similar problem with a new (to him) boat and upon tracing down the lines to check for a blockage dicovered the there-to-fore unknown filter cannister which was grossly obstructed. The pump had to work so hard to force water through the element it would overload and blow his fuse.
In addition to both sediment and charcoal filters in our water line I have a portable cannister with a sediment filter element (from Lowes) that I hook-up to our hose when we need to re-water our tanks and the amount of gunk, rust, etc. that gets pulled out--even after we have let the water run a while to presumably purge the lines--is often quite remarkable.
FWIW...
Old 02-27-2010
Well I got down to the boat with a meter and I found that the pump was drawing from 10 amps to 13 amps consistantly depending where in the cycle it was. The wires and connections were stone cold. There was no short indicated in the circuit. There is a suction filter up stream of the pump and it was clean. The breaker is a 10 amp which explains the tripping and the pump is marked "max 10 amps".
I'm at the point of replacing the pump I bought 6 months ago if no one has any further suggestions.
There looks to be an accumulator plumbed in, but the bladder must be gone because as soon as you crack a valve the pump will start up, and wiil only run a couple seconds after you close the valve. Don't know if that would have any affect.
Vexxed in Vancouver
Old 02-27-2010
captbillc's Avatar
ancient mariner
captbillc is on a distinguished road
how much pressure does the pump build up when the faucet is closed ? if the pressure switch does not shut the pump off when it should, the pump current draw will be enough to trip the circuit breaker.
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
Old 02-27-2010
Thanks for your input, That's a good thought. But the pump still draws 10 amps at the start of the cycle so it seems there must be some thing else at play.
I think I'll change it out and see if West Marine will stand behind it.
Old 02-27-2010
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Get the WM 2yr warranty so if it goes out or when you get close to the 2yr point take it in and replace it for 30-40 bucks, I have this on all pumps and water heater and glad I do
Also, if you have one of those VSR type pumps, you can do away with the accumulator
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 02-28-2010
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
Originally Posted by dillybar View Post
Well I got down to the boat with a meter and I found that the pump was drawing from 10 amps to 13 amps consistantly depending where in the cycle it was... The breaker is a 10 amp which explains the tripping and the pump is marked "max 10 amps"...
Vexxed in Vancouver
Vexxed in Vancouver,
If it's a 10 amp pump behind a 10 amp circuit breaker, it sounds to me like MAYBE everything is working as it should. You could either increase the breaker to 15 amps or get a pump that draws something like 8 amps instead.
If you are increasing your breaker, make sure your wiring to the pump is ok with that or replace the wiring with thicker wires. Also make sure whatever is supplying power to the circuit breaker (e.g. main breaker and wires) is ok with the increased current.
In the mean time, you could try running some thicker wire from an existing 15 amp circuit breaker and seeing how the pump functions, while monitoring/watching the pump closely. Not sure you want to go changing things like circuit breakers. A test done this way will give you some more information for you to work with.
**My lawyer just called. He says to tell you... Don't do any of this. Just go get a smaller pump.**
Regards,
Brad
Devising a Better Bilge Pump Don Casey Seamanship Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
Devising a Better Bilge Pump Don Casey Cruising Articles 0 06-02-2002 08:00 PM
