Old 02-16-2010
JeffC22's Avatar
JeffC22 is on a distinguished road
Black water leaking into bilge
Hi all, need help!
Yesterday I checked the bilge on the starboard side of my father's 38' Fountaine Pajot cat., and it was filled with what smelled like black water from the head. Also, in the starboard engine compartment I noticed bits of toilet paper.
Further, the starboard head is no longer pumping out (this head flushes out, not into a tank). When you try to pump it, there's no pressure. I haven't started taking anything apart yet, since I still haven't diagnosed the issue. So before I do, anybody have any clue what might be happening here?
Thanks,
Old 02-16-2010
Cruisingdad's Avatar
Best Looking Moderator
Wow, that's not pretty. Track that one down asap. SOunds like a hose has come off somewhere. This can happen when a hose clamp is not put on (or doubled) and it gets a lot of pressure behind it.
Get a bunch of bleach water and start having fun! Start with where it hooks onto the tank, then backtrack from there. You can also check the macerator hose to make sure it has not come off.
As far as the other head, it could be a number of factors. Try fooling with the dry bowl/wet bowl lever. If they stick, you can get no pressure. If that does not work, make sure the T-hull for water is open. If that is not it, sounds like you might be in the market for a rebuld or replace.
What is the make of the head?
Brian
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 02-16-2010
Wait, maybe I missunderstood, but is the head that is not flushing the same as where the black water was found? If it is a direct overboard, you obviously have a break/cut in the hose somewhere.
Brian
Com-Pac 16
Old 02-16-2010
Or the hose that used to go to the holding tank is now leaking... from the holding tank.
Old 02-16-2010
knothead's Avatar
Originally Posted by JeffC22 View Post
Hi all, need help!
Thanks,
Jeff, what is happening is that something has failed in your system and you have raw human sewage flowing around inside the boat.
Yuuuuuuck!
Go get a bunch of disinfectant, a hazmat suit, a respirator, a wet or dry shop vac and a bunch of tools and rip that disgusting system out of the boat and install a composting head.
It needn't be anything more complicated than a five gallon bucket and a bunch of coconut fiber to be cleaner, less smelly and guaranteed to never cause a problem like this aboard your boat again.
Or you could spend a little more and get a commercially made product like an Airhead or a Nature's head.
Human excrement should be stored, since it must be stored, mixed with dry compostable material. Not in a liquid form in a tank.
I repeat. Yuuuuuuuuuuk!
http://www.sailnet.com/forums/gear-m...et-report.html
Composting Toilets - Cruisers & Sailing Forums
http://www.anything-sailing.com/why-...adi-t5459.html
Ron Paul 2012
"wikijar"
Low Cost General Tools Moisture Meter? RhythmDoctor Gear & Maintenance 14 04-24-2011 08:53 AM
Bilge water BayDancer Catalina 1 07-08-2006 10:31 AM
Water, Precious Water Michael Carr Cruising Articles 0 09-02-2004 08:00 PM
Water, Water Everywhere Tania Aebi Cruising Articles 0 06-14-2004 08:00 PM
Devising a Better Bilge Pump Don Casey Gear and Maintenance Articles 0 06-02-2002 08:00 PM
