Hi,
We are going to commission our bimin project out soon to have the frame built and the cover made. We would like some input on what should or would make a good bimini. We made our last one on our Catalina 30 so we have some knowledge on the subject.
We know it needs to be high enough to stand under with a hat on if possible. I am 6’ and there will be 1 inch of cockpit covering.
It needs to still fit the solar panels and possibly under the boom.
It will need to support three or four 135 Watt or so solar panels.
Will that require stern rail re-enforcement along the sides? We plan on re-enforcing the stern rail on the stern for dingy davits.
It should go far enough aft but how far?
It should shed rain outside of the cockpit.
It will have a piece attached to the dodger.
What are any thoughts on a window to see sail trim in the bimini?
What about thoughts on the tubing placement or style for access to the grill and wind generator pole? Also free elbow room to the T part of the T cockpit?
I kinda like the one attached that is of sister boat (Islander Freeport 36'). It seems to go to stern enough and we plan on having dingy davits. The frame would need to be different. This baot has a heard dodger top.
How far forward should it come or can it come and still see sail trim?
I was thinking at one time it could have another piece on the aft part that could fold out and down a bit for further shade. Kind of and extended awning. Good bad idea?
Thanks for your imput in advace,
Chip
s/v Elegant'sea IF36-B
