02-18-2010
Midwest Puddle Pirate
Some senders are made to swap the arm to the other side, some are not. If you can't swap the arm, and you can't get a correct sender, cut the arm off and weld it on the other way. You may have to be a little inventive to get it done, but I'm sure it can be done. Just don't burn the sender.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. John USYacht 27 "Cora Lee"
