Like Tree9Likes
  #121 (permalink)
Old 01-15-2012
JVallely is on a distinguished road
That's a lot of creosote. Have you considered insulating your flue? The hotter it is, the less combustion gas condenses inside it.
JV
  #122 (permalink)
Old 01-15-2012
mtboat's Avatar
mtboat is on a distinguished road
On a regular house sized pipe it would not be so bad but this is a 3 inch pipe. Not a bad problem....I run a plumbers snake through the top end every other day and it all falls back in the stove.
Might be the type of wood. Our western larch burns hot so less creosote, but the fir and pines seem to have a lot.
Hard and fast
  #123 (permalink)
Old 01-16-2012
WanderingStar is on a distinguished road
I've often wondered about the heat and sparks from the stack. Two years ago I sailed in a cold October rain on a classic boat (W Warner's "Mary Loring"). The owner lit up his coal stove. When I asked him about damaging the main, he told me to put my hand above the stack. The flow was warm, but not hot. I don't know if that was the stove, the stack, the fuel, or all of the above.
  #124 (permalink)
Old 01-16-2012
You're staying on top of it, then. I've seen 2 chimney fires, and they're pretty scary. They were like a 6 or 8 foot blowtorch spitting burning embers all over the roof and threatenning to blow apart the pipe joints. The second one, I had a chimney flare on hand. Put it out in seconds.
But I don't know if I'd want to use one on a boat. They work by producing massive quantities of smoke that displaces the oxygen in the flue. Probably make a real mess in a marina. You'd want one the size of a birthday candle.
I don't know if coal sends burning sparks up a flue the way wood can. I know hard coal burns hotter than wood does, but I don't believe the chemistry is the same. Pitch pockets in wood can burst and expell burning embers. Coal doesn't coat the flue with flamable creosote, either.
JV
  #125 (permalink)
Old 01-17-2012
Waltthesalt is on a distinguished road
I use a wood stove I got at a boat flea market. Propane's got explosive concerns. Kerosene probably less mess. I use charcoal and have plenty of room for it for what my need. Pellets might also work, cheap and compact. You've got to shovel out the ash.
Walt Elliott
Kingston WA
Puget Sound
Cal-29
  #126 (permalink)
Old 01-18-2012
Brent Swain is on a distinguished road
I have used oil before, but when I got frozen in a great anchorage with lots of oysters,venison , grouse and cod , etc. I had to keep going back for more diesel. So I converted it to wood , and lived happily ever after.
I have several wood stoves to build here, for people who are getting nervous about the cost of oil. One couple I know, living on an Ericson 37 spend $280 a month on diesel in winter, more than my total cost of cruising. It takes me 15 minutes to gather a weeks supply and gathering it is far more pleasant than going to work to pay for diesel. Wood won't overflow and flow thru your cabin. You can put an airtight stove out by simply closing the air intake. You can put a wood fire out with water.
When I was building my first boat, I was laughed at and ridiculed for saying I was using a wood stove, and not diesel. 6 years later, out of 6 boats anchored in Montague Harbour, four had wood stoves. Now the majority of full time BC cruisers I know use wood stoves, most having given up on oil. In the city , wood can be hard to find, but outside the city you are surrounded by it, in BC. .
It is very important that any wood stove you have has a big enough firebox and is airtight, so you can control the burn rate. Mine has ran for up to 14 hours burning time on a single load of wood. Of course when I get up in the night to use the head, I try stuff a few more sticks in the stove.
Stove pipe should be as straight as possible,to facilitate cleaning. Better to run them at an angle if needed, rather than use elbows.Best if you can run a pole down them, straight into the firebox. The best stove pipe here in BC is the four inch stainless tubing , available in scrapyards for under $2 a pound , from the pulp mills.
I put mine in the back corner of the wheelhouse, so I could put my stovepipe in the stern. This way there is no chance of downdraft from sails , no chance of burning a hole in a sail dropped on it, and no chance of smoke in my face when anchored.
Another option is by your mast, so the stove pipe is among the shrouds. An outside air intake eliminates down drafts.
The best heat shields I've found are aluminium sheet with an inch of fibreglass house insulation behind them . Aluminium dissipates the heat rapidly so there are no hot spots. The bigger the sheet the lower the temperature i
I pile my firewood in the cockpit in winter. Building supplies have plenty of free tarps used to cover lumber piles, which you can use as disposables to cover your firewood, altho a bit of rain on it doesn't hurt much. .
Brent Swain, Yacht designer, Builder, and author of "Origami Metal Boatbuilding"
  #127 (permalink)
Old 01-19-2012
Thank you, very informative.
  #128 (permalink)
Old 01-19-2012
-OvO-'s Avatar
Owl
-OvO- is on a distinguished road
wood has bugs. Sometimes those bugs like to eat wood. Generally you should keep your woodpile at a good distance from your wood structures. Coal, otoh, doesn't have bugs. Pelletized fuel is pretty-much bug free as delivered, not sure how well it resists infestation.
  #129 (permalink)
Old 01-19-2012
Never seen a bug problem in 40 years of wood burning.
With my stainless chimney, I use a chimney fire to clean it sometimes.I pour diesel down ,open the door and stick a piece of toilet paper in the pipe, soaked in laquer thinner to get it started. Can be hard to start sometimes ,takes several tries.
When it gets going, it burns like a blowtorch. I quench the pipe down with water on the outside, until the fire goes out.
If you wake up in the middle of the night, and your boat feels like a sauna, it means your stove is full of nothing but coals, and is about to go out if you don't get up and stuff some more wood in.If you don't get up , things will begin to get very cold in the next hour. Stuffing more wood in will drop the temperature of the stove and cabin , by absorbing the heat, but the stove will then probably keep burning till noon.
Grates are for coal, wood burns best in its own ashes. An old steam tug operator said that when he took the grates out of his boilers ,his firewood consumption dropped by 30%
Cast iron cook stoves have grates ,which makes the firebox extremely tiny and short burning.
Friends have thrown out the grates, and built an airtight firebox liner for such stoves , doubling the size of the firebox and making the burn rate controllable.
A plastic squeeze bottle of diesel makes good "West Coast Kindling."
A splitting maul for splitting wood is far easier to use than an axe.
A cheap Cambodian Tire 15 inch chainsaw makes gathering beach wood extremely easy and quick. They only last three years, but you definitely get your money's worth in that time, then buy another cheapie.
Don't pack armloads of firewood over piles of beach logs. Airmail ( toss) it over them, one piece at a time, then gather them up later on the flatter ,safer, more easily accessible beach.
  #130 (permalink)
Old 02-02-2012
Capt Len is on a distinguished road
My little home made wood stove;no grates, lined with fire brick and completely air tightable will run all night on a load of hard wood pallet chunks. Gold plated glass door makes for great ambiance .Only cost is the occasional carbide blade in the skill saw when I don't get between the nails.
Brent Swain likes this.
Are you scared of wood? CharlieCobra General Discussion (sailing related) 35 04-05-2010 02:32 PM
Propane or Alcohol Stove? bsfree General Discussion (sailing related) 61 03-08-2010 09:42 PM
How to connect American propane line to European stove faithab General Discussion (sailing related) 3 05-25-2006 04:29 PM
portable propane stove rbtpfe9 Gear & Maintenance 11 11-02-2004 02:58 PM
Refilling Propane Tanks Doreen Gounard Gear and Maintenance Articles 0 09-01-2003 08:00 PM
