Wood, Diesel or propane bulkhead heating stove? - Page 19 - SailNet Community
 15Likes
post #181 of 181 Old 10-31-2013
Andrew65's Avatar
Re: Wood, Diesel or propane bulkhead heating stove?
In cities, construction sites can be a good source of wood, as can building supplies.
If you want to get fancy about collecting wood. I collect clean sawdust (without glue and such) and press homemade logs. You take a pvc tube about a foot long drill a lot of small holes in it. Put a removable endcap on it and fit it to a basic squeeze glue gun. Fill it with watered down sawdust with spacers (washers for example) every inch or so, pull the trigger to press out the water, then pop them out. Let them dry for a while and presto homemade logs. You can find the contraption on youtube for a better description than mine, but it is well worth trying to make if you have a lot of sawdust at hand.
Andrew65 is offline
Are you scared of wood? CharlieCobra General Discussion (sailing related) 35 04-05-2010 03:32 PM
Propane or Alcohol Stove? bsfree General Discussion (sailing related) 61 03-08-2010 10:42 PM
How to connect American propane line to European stove faithab General Discussion (sailing related) 3 05-25-2006 05:29 PM
portable propane stove rbtpfe9 Gear & Maintenance 11 11-02-2004 03:58 PM
Refilling Propane Tanks Doreen Gounard Gear and Maintenance Articles 0 09-01-2003 09:00 PM
