Honda eu2000i and air conditioning - Page 6 - SailNet Community
 1Likes
post #51 of 84 Old 01-30-2012
night0wl's Avatar
Bought mine from wisesales and it was ~$900 delivered.
Also look at hard start capacitors. Save some bucks vs buying something prepackaged
S/V Jendai
Beneteau 343
night0wl is offline
post #52 of 84 Old 01-30-2012
Thanks! Wise is where I bought the one I have. I was saving them for last to check. I called and they say $899 delivered which is I think 100 less than I paid for my first one. I'll probably order one from them in a week or two. (After I'm done looking for that *less than* $900 unicorn.)
Sailinstuff is offline
post #53 of 84 Old 01-31-2012
S/V Antares
rwy36's Avatar
Based on their Web site (which requires registration to see the pricing), a Honda Eu2000i can be had from Mayberry's for $899 with free shipping. For another $100 more, there is a model of the Eu2000i with a 30A twist-lock connector also. Visit http://www.mayberrys.com for the details (no affiliation, just passing along the local knowledge).
Good luck,
Bill
rwy36 is offline
post #54 of 84 Old 02-03-2012
Mayberrys has the EU2000i for $899 and the companion unit for $999. They're advertising free shipping for orders over $199. You might check them out at www.mayberrys.com.
robertsapp is offline
post #55 of 84 Old 07-16-2013
Re: Honda eu2000i and air conditioning
Just curious why the SPP6E was chosen for the test vs. SPP6. I called Supco Tech Support about this and they mentioned they would not recommend the E model in a generator config .. Something about keeping the start charge in the cap too long or something. Thoughts?
ov10mech is offline
post #56 of 84 Old 07-16-2013
One of None
deniseO30's Avatar
The supco hard start kits heat up. PTC I think they are called (getting old and forgetful here) lol A traditional relay and start cap would work but really is not necessary.
Many if not all compressors in window type units use rotary compressors. Marine and central may use a scroll type compressors. All are very very low amperage starting.
Remember name plate rating are not actual it's a guide. To get real amperage draw you need a clamp on type meter. You will be surprised how little amps they draw even though the name plate suggests much more.
Hard-Start Devices: Insurance For The Compressor
My last project!
deniseO30 is offline
post #57 of 84 Old 07-28-2013
Exclamation Re: Honda eu2000i and air conditioning
Originally Posted by gershel View Post
Honda eu2000i and Air Conditioning
Just heard about a new product from Dometic. It's called a SmartStart controller. It reduces the amount of amps needed to start an air conditioner by 65%. I spoke to a tech from Dometic, who seemed to think, that a Honda 2000 could run a 16,000 btu Cruisair a/c. The cost for this unit is about $360. Sounds interesting. Sure would keep my wife "happy". Has anyone heard anything about this. It's only been available a few months.
Marc
I, just this week, finished a year long saga with the Honda 2000 and a 16K BTU air conditioner. This is what I learned:
  • The Smart Start is specifically designed to work with a Dometic AC unit; however, it works perfectly well with non Dometic units.
  • The Smart Start will allow a Honda 2000 to power only certain Dometic 16K AC units - they must have the 410 coolant.
  • I installed a Smart Start on a non Dometic unit and managed to get the ramp up amperage down to 29 amps. The Honda 2000 just couldn't do it consistently. Sometimes it could, mostly it couldn't.
  • I installed a Victron Energy Multiplus inverter charger that has a power assist mode and all works well now. This was not an inexpensive install; however, it greatly upgrades my electrical system and it needed it anyway. The alternative was a genset and that would have been even more expensive and, I would have still had to upgrade the electrics.
Do your home work with the Smart Start- Dometic is very specific on which AC units will be able to accept it and be powered by a Honda 2000.
Good Luck.
spcharby is offline
post #58 of 84 Old 08-17-2013
odd ball question = where is everyone storing these when underway - lazarettes, strapped to the decks/ One of our big problems to figure out
thanks
last mango is offline
post #59 of 84 Old 08-17-2013
trantor12020's Avatar
Under nav table.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #60 of 84 Old 05-30-2014
Send a message via AIM to negrini Send a message via Yahoo to negrini Send a message via Skype™ to negrini
Lazarette. Be careful with the hot exhaust.
Nave Rara
Beneteau Oceanis 43
negrini is offline
Re-install the marine air or keep the window shaker? mikethecapt Cruising & Liveaboard Forum 4 10-23-2009 04:48 PM
Honda EU2000i newsailor123 Gear & Maintenance 6 11-27-2003 10:06 AM
