companion way doors - Page 2 - SailNet Community
post #11 of 11 Old 12-31-2009
I built set of removable swinging doors for my Hunter 27 back in 1983. Loved them, they fitted over the companion way boards. I used two sheets of teak plywood screwed together with screen sandwiched between. I cut a rectangular hole on the inner piece. I used a table saw with the blade at 45 degrees to cut slots in the outer piece. Trimmed all the edges with teak veneer strip using resorcinol glue. I also made the liftoff hinges. I bought a stainless strip hinge from McMaster Carr with no screw holes. I cut it apart and welded the pin in place on one half by just fusing it with a tig torch. Then I drilled the screw holes where I wanted them. I'll probably build a set for this boat, much more livable.
GaryHLucas is offline
Female Cruising Companion Wanted lonelywolf Crew Wanted/Available 4 11-26-2006 03:59 PM
Sailing Companion Wanted DICKWATERS Crew Wanted/Available 0 01-06-2004 07:50 AM
Companion wanted for Caribbean cruise guidoke Crew Wanted/Available 7 12-15-2003 09:14 AM
Seeking - Female Cruising Companion leeshore Crew Wanted/Available 0 09-29-2003 07:53 AM
Companion for Bahamas cruise wanted guidoke Crew Wanted/Available 0 09-03-2003 10:46 AM
