Replacing lines - Page 2 - SailNet Community
post #11 of 14 Old 02-24-2010
Closet Powerboater
MedSailor's Avatar
Don't have a furler (yet), so won't try to speak to that. For your jib sheets if you like the larger line because it's easy to handle, than stick with it. I have HUGE job sheets on my new boat as well and while I find them easy to hang on to I can only get 3 wraps around the winch, and with our monster headsail in high winds I find that isn't enough. I'll be downsizing the sheets in order to be able to get another wrap on the winch.
Whatever you do, make sure you don't change the size too much if you have self tailing winches. You don't want to find that your new line won't work with the ST winches.
Medsailor
MedSailor is offline
post #12 of 14 Old 02-25-2010
I don't discuss my member
zz4gta's Avatar
No reason on earth to have anything bigger than 1/2" on any reasonable sized boat. A single braid (salsa, apex, etc) for the furler in 5/16 or 3/8 would work really well. I'd probably use 3/8 or 7/16 for jib sheets. Always go as small as possible that you can still handle well. Smaller lines run better and hockle less.
Merit 25 # 764 "Audrey"
zz4gta is offline
post #13 of 14 Old 02-25-2010
And are lighter and less expensive.
sailingdog is offline
post #14 of 14 Old 02-25-2010
Nothing will curl the leech of a head sail faster in light air than the weight of over-sized sheets. A curled leech will cost boat speed. With out boat speed it is hard to keep the slot open and the leech from curling. Do you see the downward spiral here? 1/2 inch is big enough! IMHO
Never Forgotten
bubb2 is offline
Leading Sail Control Lines Aft Sue & Larry Gear and Maintenance Articles 0 08-11-2003 09:00 PM
Replacing Shroud Lines RookieHunter Gear & Maintenance 1 11-28-2002 07:37 PM
Replacing lines wannasail Gear & Maintenance 2 09-02-2002 05:28 PM
Spare Dock Lines Mark Matthews Gear and Maintenance Articles 0 03-10-2002 08:00 PM
Wind Michael Carr Seamanship Articles 0 08-31-1997 09:00 PM
