03-01-2010
1975 Newport 28
Originally Posted by mitiempo
You won't get galling with stainless and aluminum, you get galling with stainless and stainless. I would not use self tapping screws. Rivet or machine screw. Why wouldn't the rivet gun fit?
I'm looking at using the Harken 300 series fairlead block (the 300-31), and the rivet gun head would have to fit between the cheeks, which don't look very wide. Also, the bottom rivet would have to be within a few inches of the deck, and with the cheek in the way the length of the gun's handle would preclude getting it down there -- unless I could put in the bottom rivet with the block pointing down, then pivot on the rivet [rhyme not intended] and put the top one in.
Would that be possible with a plastic isolation washer between the block and the mast to provide a bit of slippery friction?
S/V Free Spirit
Monrovia, MD
