Mast Drilling - SailNet Community
post #1 of 56 Old 02-25-2010 Thread Starter
Handsome devil
Stillraining's Avatar
Mast Drilling
Well this was sort of scary...
I mean you really only get one shot at it and it better be right.
As some of you know I had my mast step rebuilt and along with that a SS base plate has been made to accommodate both the positive through bolting of my mast to meat Category 1 offshore rules and also for deck tie rod installation..
Well we just drilled the mast with a 1 1/4" hole saw...We took the base plate and used the two mast winches to suck it up tight...basically self aligning itself by the Derlin donut we cut to the ID of the mast that's now bolted to the new base plate. Then drilled away.
This is the first time I have ever drilled a new hole into a mast..it was a little nerve racking...check, double check, a triple check then a now or never kind of thing.
I'm Pretty confidant it will all line up in the boat..
The pin is 1" SS with an 1/8" Derlin bushing all around isolating the two metals hence the 1 1/4 hole..I think it will work well .......I hope....
I need a beer! ..
"Go Simple...Go Large"
Relationships are everything to me..everything else in life are just tools to enhance them.
The purchase price of a boat is just the admittance fee to the dance...you still have to spend money on the girl...so court one with something going for her with pleasing and desirable character traits others desire as well... or you could find yourself in a disillusioned relationship contemplating an expensive divorce.
Stillraining is offline
post #2 of 56 Old 02-25-2010
Good luck Still... Hopefully, mr. murphy was far from you when you did this.
sailingdog is offline
post #3 of 56 Old 02-25-2010 Thread Starter
Handsome devil
Here is a picture of the new base....Should I bother Polishing it?...is there a benefit?
post #4 of 56 Old 02-25-2010
tdw
Super Fuzzy Moderator
tdw's Avatar
I feel your pain Still old friend. Whenever I need to drill holes in the Womboat I go into a form of suspended animation coupled with total paranoia. I hate it.
Which is why I have a whole list of todos virually all of which require drilling holes.
Pass me one of those beers would you ?
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #5 of 56 Old 02-25-2010
tager's Avatar
You gotta polish it!
tager is offline
post #6 of 56 Old 02-25-2010
Polishing it reduces the chances of corrosion setting in quickly... makes it look pretty and last longer.
post #7 of 56 Old 02-25-2010
Still,
The new base looks expensive. A friend of mine is doing work along the same lines on a Pearson 36 ketch. $400 for steel, and a whole bunch more for aluminum. He's thinking about going the Charlie Cobra route and doing it himself with locust or ashe.
sailhog is offline
post #8 of 56 Old 02-25-2010 Thread Starter
Handsome devil
OK Polish it will get...
Womby....Here ya go Mate!...
PS: When you visit I wont have to twist your arm to drink this stuff...Wonderfull!....Might just have to build in a Kegerator into the boat now.....Ah!...who needed two heads anyway...
post #9 of 56 Old 02-25-2010
On the hard
CharlieCobra's Avatar
Drilling that would make me as nervous as a cat on a hot tin roof, especially along the seam like that. Hell, looking at it makes me nervous....
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
CharlieCobra is offline
post #10 of 56 Old 02-25-2010
I'd point out that putting a reinforcing collar around the mast might make sense, given that you've drilled two rather big holes in the weakest part of it...
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
