Took the windlass apart today - found something interesting things - Page 2 - SailNet Community
post #11 of 46 Old 02-28-2010 Thread Starter
Glad I found Sailnet
Bene505's Avatar
Brad—
Hope you checked the bolts from the hardware store with a magnet. Good marine grade stainless steel is NON-MAGNETIC. The cheaper stainless steel is magnetic.
Dog,
Yes I did bring a magnet to Ace hardware store with me. The bolts are ok.
Most of Ace's stainless steel hardware were non magnetic. I actually tested many of their products. About 30% of their cotter pins were not ok. It looked like maybe they got a refill of inferior parts. I plan to tell them about it next time I'm there.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #12 of 46 Old 02-28-2010 Thread Starter
Bene505's Avatar
Originally Posted by thinplaces View Post
I would replace those brushes, what do they cost $15 a piece?
It also looks like the gear (that the worm gear drives) is worn.
Thinplaces,
I'll check the pricing for the brushes. Philsboat on the AS site said they are about 1/3 used up. I really don't want to mess with them if I don't have to, those springs are under a lot of tension.
I checked into the wormgear (as I've since learned it's called). After carefully reviewing the price (!), I won't be replacing it this time around, unless it's completely shot. What do you think?
Regards,
BRad
Bene505 is offline
post #13 of 46 Old 02-28-2010
billyruffn's Avatar
Brad,
I now know where to turn when my 20+ yr old Nilson craps out. Good post!
PS. It's 80 this evening in Iles de Saintes. Full moon. French wine. Ceviche for dinner (dorado). Life is good. Make sure you get here!
billyruffn is offline
post #14 of 46 Old 02-28-2010 Thread Starter
Bene505's Avatar
I would replace those brushes, what do they cost $15 a piece? ...
Thin,
I promised that I'd look into the brushes. The 4 brushes ended up being $115 on the IMTRA (Lofran's parts) website. (They are probably cheaper through a non-marine source, I'd bet.)
I'll stick with the one's I have for a bit longer. Thanks for the lead on those.
Regards,
Brad
Bene505 is offline
post #15 of 46 Old 02-28-2010 Thread Starter
Bene505's Avatar
Originally Posted by billyruffn View Post
Brad,
Billyruffin',
I actually had to look up Iles de Saintes on Google maps. Congratulations for getting there, in all the facets of life it took to get there. I knew you were headed south. Wow!
Let me know if you want any crew for the return trip.
Regards,
Brad
(OK, I had to look up Ceviche too.)
Bene505 is offline
post #16 of 46 Old 02-28-2010
sd-
I'm a Krytox fan, but if those parts are in the oil bath, wouldn't that be a waste? Better to stick with greases and oils that use the same base (petroleum or otherwise) if they're going to contact each other.
hellosailor is offline
post #17 of 46 Old 02-28-2010
Somewhat Senior Member
mgmhead's Avatar
What an awesome post. Thanks for sharing. Well done and congrats, expect to hear soon that it works perfectly.
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
post #18 of 46 Old 02-28-2010
Handsome devil
Stillraining's Avatar
Regards,
BRad
One of my favorite saying " If it ain't broke ____ ____ __"
"Go Simple...Go Large"
Relationships are everything to me..everything else in life are just tools to enhance them.
The purchase price of a boat is just the admittance fee to the dance...you still have to spend money on the girl...so court one with something going for her with pleasing and desirable character traits others desire as well... or you could find yourself in a disillusioned relationship contemplating an expensive divorce.
Stillraining is offline
post #19 of 46 Old 03-01-2010
Brad,
I know some will disagree, but once you're 'inside' a piece of equipment like that, I would be inclined to think that you're then in a typical industrial atmosphere.
Given that assumption, I would bet that those brushes, and the gear, are pretty typical industrial components.
Perhaps in the future you could check industrial suppliers for the brushes and for the gears.
Also, 30% mechanical wear off of a motor brush doesn't equate to 30% reduction in service life.
Because you need (about) 30% of the length of the brush to hold it in proper position, therefore you can only use the remaining 70% of the length (from when new), so I think those brushes are approaching 50% of life expectancy.
I don't claim to be an expert, but you mentioned that the brushes were replaced once, so perhaps you could check the brushes at the end of the '10 sailing season?
Great thread.
thinplaces is offline
post #20 of 46 Old 03-01-2010
When I suggested Krytox, I wasn't aware that the parts in question were in an oil bath. I wouldn't have suggesting using Krytox in that situation.
Originally Posted by hellosailor View Post
sd-
sailingdog is offline
The E-List: Great things to do today with Lorne Mallin (Vancouver Province) NewsReader News Feeds 0 05-09-2006 05:15 AM
Windlass - Horizontal or Vertical? PBzeer Gear & Maintenance 8 03-03-2006 05:51 AM
Manual Anchor Windlass rclampitt Gear & Maintenance 4 12-03-2002 06:04 PM
Ten Things We Wouldn't Cruise Without Sue & Larry Gear and Maintenance Articles 0 12-12-1999 07:00 PM
Ten Things We Wouldn't Cruise Without Sue & Larry Cruising Articles 0 12-12-1999 07:00 PM
