Another broken screw thread (in wood) - Page 2 - SailNet Community
post #11 of 27 Old 03-03-2010
bljones's Avatar
Pappy, those extractors might be a little big for a #6 or #8 wood screw, especially one with a broken head.
bljones is offline
post #12 of 27 Old 03-03-2010
If all else fails and you have enough diameter in the stuck scrwe try an "easyout". It's more common to use easyouts in a steel bolt. You drill a hole down the center of the bolt that you want to extract. You then screw in the easyout into the hole. The easyout is threaded CCW... opposite to the normal screw thread. It's like a screw tap but in the opposite direction. Once the easy-out is screwed in you can use it to unscrew the stuck screw as turning it in to pull out the stuck fastener only tightenes the easyout. Easyouts are available in most hardware stores.
good luck
Waltthesalt is offline
post #13 of 27 Old 03-03-2010
poopdeckpappy's Avatar
It's the tool that's important not the size besides you can get them smaller, and #6 or 8 wood screw is kind of a small fastener for a handhold
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #14 of 27 Old 03-03-2010
i really suggest the plug cutters like was pictured above. it really is the best safest way
edit another option is a hole saw with the guide bit removed. they sell them very small if you look, i have seen them with an outside dia of 3/8
scottyt is offline
post #15 of 27 Old 03-03-2010
One of THOSE!
2Gringos's Avatar
you guys must have steadier hands than I do. Fostners, plug cutters, and hole saws usually give me fits in a hand drill. I am okay with a drill press, of course, but have really marred some wood up trying to do it by hand.
Expat Life in the Devil's Triangle:
2Gringos is offline
post #16 of 27 Old 03-03-2010
Glad I found Sailnet
Bene505's Avatar
good luck
If you do this method, make sure you drill a hole in the exact center of the screw you are removing. Use a punch or something. And drilling into steel isn't easy to start with.
I tried using one and was off center a bit, which is why I'm looking to cut a slot in the the top of the bolt so I can unscrew it.
Also, any pictures?
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #17 of 27 Old 03-03-2010
There is a tool like a small hole saw, but longer. It cuts in turning left, grabs the screw and draws it out by friction. I don't remember the name. Try Googling "broken screw extractor". If you can spring the rail out at all, consider using a hacksaw blade to cut the screw at the seam.
WanderingStar is offline
post #18 of 27 Old 03-03-2010
tager's Avatar
I would make a huge electromagnet and just suck the screw into it.
Make sure you remove everything else that is metal from the boat and surrounding area.
tager is offline
post #19 of 27 Old 03-03-2010 Thread Starter
Unpaid Intern
josrulz's Avatar
Sounds like a plan!
By the way, I started a new thread about rebedding these darn things. Seemed like a different subject really, so hope that's OK...
1984 Sabre 34 Mk I
josrulz is offline
post #20 of 27 Old 03-03-2010
One of THOSE!
2Gringos's Avatar
Is this a steel, non-stainless screw? You don't want any screws that are magnetic in a boat, anyhow, do you?
2Gringos is offline
Are you scared of wood? CharlieCobra General Discussion (sailing related) 35 04-05-2010 03:32 PM
broken screw removal sailhog Gear & Maintenance 23 01-17-2010 09:13 PM
Wood choice, for backing support, question ?? Jasper Windvane Sailboat Design and Construction 5 12-07-2009 09:19 AM
Help please with broken screw/handrail FrankLanger Gear & Maintenance 3 04-09-2006 11:55 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
