Another broken screw thread (in wood) - Page 3 - SailNet Community
post #21 of 27 Old 03-03-2010
Mechsmith
There is made a screw extracter that fits in a drill and goes over the stub. Drill (turning backwards) with the tool until it grabs the screw and spins it out. It's kind of a backwards hole saw with internal teeth.
Good hardware store stuff. Or McFely's paper catalog. They wern't in the online catalog.
Seafarer 29 KCB
Mechsmith is offline
post #22 of 27 Old 03-03-2010
Somewhat Senior Member
mgmhead's Avatar
Jim,
One letter and one numeral ..... C4 !!!!!!!!!
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
post #23 of 27 Old 03-07-2010 Thread Starter
Unpaid Intern
josrulz's Avatar
Ha ha! Fortunately, there was no need for major explosives!
For anyone who might be interested, I got the screw out this weekend. I did try using an extractor. I bought some a new set of decent quality, but it did not work. The top of the broken screw was too rounded, so the tool kept slipping off and wouldn't grab.
So I ended up just drilling around the hole a few times, and pulled the handrail out. I ruined the hole. However, there's space nearby to add a new screw hole and bung if needed. So the handrails are now at home ready for stripping, etc.
The really good news though is that I ended up using the new extractor the same day on a stripped screw for a completely different project. Soooo, I suppose it all worked out.
Of course, there is still much work to do!
Thanks again everyone for the tips.
-J
1984 Sabre 34 Mk I
josrulz is offline
post #24 of 27 Old 01-21-2013
Smile Re: Another broken screw thread (in wood)
Originally Posted by bljones View Post
use a plug cutter bit to cut around the screw, remove the rail and then epoxy in a plug.
The One way to remove the Broken wood screw bit is using Plug cutter Bit, and the other way is to use a small size Drill bit to clear off the Bit totally to insert the fresh or new one at the same place. The most impotent thing to remember is its better to choose a genuine company like "Mutualscrew and supply" to buy quality and wide range of wood screws. Hope this will be helpful for you guys.
gurubunny is offline
post #25 of 27 Old 01-21-2013
Old as Dirt!
svHyLyte's Avatar
Considering that the thread/conversation is some 3 years old, I would guess the original poster (AKA "OP") has resolved his problem at this point, Non?
svHyLyte is offline
post #26 of 27 Old 01-21-2013
Seņor Member
PorFin's Avatar
FWIW (just to add another option that has yet to be raised):
UnScrewUms
These puppies will remove a lot less material than a plug cutter.
________
'85 BYB Vagabond 39
PorFin is offline
post #27 of 27 Old 01-22-2013
poopdeckpappy's Avatar
Not to mention it looks like a advertisment/spam for a vendor by the vendor
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
Are you scared of wood? CharlieCobra General Discussion (sailing related) 35 04-05-2010 03:32 PM
broken screw removal sailhog Gear & Maintenance 23 01-17-2010 09:13 PM
Wood choice, for backing support, question ?? Jasper Windvane Sailboat Design and Construction 5 12-07-2009 09:19 AM
Help please with broken screw/handrail FrankLanger Gear & Maintenance 3 04-09-2006 11:55 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
