polishing plex - Page 2 - SailNet Community
post #11 of 24 Old 03-05-2010
Its the UV radiation breaking down the plastic. No matter what you do to resurface them, the haze will continue to come back.
I think there are spray on products that promise to block UV on clear plastic, but its not going to be permanant. There are UV blocking films, but again its not going to be a perfect (it will peel eventually). Acrylic just can't resist sunlight very well. Polycarbonate and glass is a much better material for long term exposure.
JamesG123 is offline
post #12 of 24 Old 03-05-2010
Question
Do these polishing products work on polycarbonate (Lexan) as well as acrylic? If so, how long does it last on Lexan?
TortugasLane is offline
post #13 of 24 Old 03-05-2010
They work on pretty much all plastics. I would not expect there to be much difference between the perfomance of Lexan or Acrylic after polishing.
r.furborough is offline
post #14 of 24 Old 03-05-2010
One thing, some Lexan or Polycarbonate is sold with a UV-resisting coating. If you polish it, the Lexan will deteriorate more quickly, since you'll effectively be removing the coating.
sailingdog is offline
post #15 of 24 Old 03-05-2010
Another Question
Wouldn't you think that if Lexan needed polishing that it probably does not have a UV light protection film on it? Or is there another reason why Lexan might need polishing? I guess it could be physical scratches. How do you know the difference between UV light deterioration and physical scratches?
post #16 of 24 Old 03-05-2010
Clouding, and yellow hazing esp. around the edges, is UV damage. Scratches and 'crazing' are physical scratches like from salt. Scratches accelerate the UV degradation because they open up more surface area in the plastic to be attacked.
post #17 of 24 Old 03-06-2010
What are your choices?
So no matter what the cause, once you have hazing, crazying, scratches etc., you have no choice but to polish or change out the plastic. Is that the correct conclusion?
post #18 of 24 Old 03-06-2010
Yeah, pretty much. Acrylic left exposed to sunlight should be considered a consumable item that will need periodic replacement.
post #19 of 24 Old 03-06-2010
Courtney the Dancer
jrd22's Avatar
I usually polish our Lexan side windows and the hatches once per year. Unless there are deep scratches I just use the Novus #1 and #2, deep scratches need #3. Our hatches were really bad when we bought the boat. Now they look OK and you can see through them but they don't look shiny new. Novus is good stuff.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #20 of 24 Old 03-06-2010
FSMike's Avatar
My lady has used insulator wax as preventive maintenance for decades. It works well to help fend off UV damage, scratches, etc., before they happen. Don't know how well it would work to bring back stuff that's already damaged.
FSMike is offline
Cleaning & polishing gellcoat non skid dillybar Gear & Maintenance 9 06-08-2010 09:20 PM
Home Made Diesel Polishing System Q cruisingmom Diesel 25 01-27-2010 05:23 PM
Fuel Polishing jr438234606 Gear & Maintenance 14 09-11-2006 11:48 PM
Fuel Polishing? GarrettK Gear & Maintenance 2 06-03-2005 05:33 AM
