Old 03-06-2010
scraph is on a distinguished road
Main Winches for Spring Lines...
Yes, you read that right. My boat (32' C&C displacing ~11000lbs) has cleats and open chocks bow and stern for bow and stern lines ... however, there is no such thing amidships. So ... spring lines are secured boat side by wrapping them around the main winch.
Opinions?
1981 C&C 32
Old 03-06-2010
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
You can use the same breast line cleats for springs........i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
Old 03-06-2010
I would recommend using the cleats rather than the winches... the winches may not be mounted to resist loads from the directions of the docklines.
Another option is to install amidships cleats on the genoa fairlead tracks. Schaefer, Garhauer, and Forespar all make them.
Old 03-06-2010
FSMike is on a distinguished road
There's no law that says you can't run spring lines from the bow and stern cleats towards the dock cleat nearest the middle of the boat. As far as winches go, if you've got a fair lead go for it. Just don't trip over the lines.
Old 03-06-2010
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
On our C&C 35 MKIII we follow Saildogs lead. Cleats are on our Genoa Tracks for the spring line. makes a good central point also when rafting up for forward and rear spring line attachment to other boat to help "lock" the boats together to prevent banging. Also since the spring is our first line we attach we docking it is in a desirable location amidships the wides point on our boat when pulling up to reach and pull the dock line off the dock hooks. (not sure if I explained that correctly). We have the Carhauer ( 11/4" track) ones and are quite happy with them.
Not sure I would feel safe with all the different angles a spring line takes floating around in a slip that I would leave my boat attached that way in addition the the added strain it would put on your winches.
Dave
___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Old 03-11-2010
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
Winches are set up for more of a constant load, the needle bearings are designed to transfer the loads as the rotate and come under load. There would be no harm in temporary using for a spring line, but for repeated cyclic loading it would be hard on both the bearings and the races, especially if an aluminum drum.
Cal 9.2 #19 SilverSwan
Old 03-11-2010
jackdale's Avatar
jackdale will become famous soon enough
You can also spring from shrouds - if you have chafe protection on the spring line.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 03-12-2010
This is a really bad idea IMHO... Putting stresses like that on the rigging is a BAD IDEA.
Old 03-12-2010
AdamLein's Avatar
AdamLein will become famous soon enough
Recommend strongly against using shrouds. Also recommend against using stanchions, but I do it anyway :P
Also recommend against using bow and quarter cleats to spring the boat in or out of a berth. In this case it's crucial to have a midships cleat mounted as close as possible to the boat's center of lateral resistance, otherwise the bow or stern will swing out.
If you're using them statically to arrest fore and aft motion of the boat in her slip, bow and quarter cleats will work fine. In this case I think a winch will work reasonably well also, unless you happen to get hit by a tremendous and gusty storm.
s/v Essorant
1972 Catalina 27
Old 03-12-2010
Bad Adam...bad, bad Adam...
Yup, true that.
The problem has to do with how the winches are mounted. If you have the winches mounted on the cockpit coaming, they're often pretty strong fore-and-aft, but fairly weak athwartships... and if you're using it as a spring line to pull the boat in towards the dock, they can often tear out.. I've seen some really gruesome photos where the winch basically tore the entire coaming off the boat because it was used for a dockline.
Leading Sail Control Lines Aft Sue & Larry Gear and Maintenance Articles 0 08-11-2003 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
