Old 03-06-2010
fparry's Avatar
fparry is on a distinguished road
Bottom Paint recommendations for Great Lakes
I plan on prepping and painting the bottom of my newly acquired Santana 27 in a few weeks. I have read that the choice of bottom paints changes with local and water conditions.
The boat is currently on Lake Erie and upon launch will be transported to Lake Ontario where it will be docked.
I have no idea what type of paint is currently on the boat but regardless I want to make sure I prep it correctly and apply the best paint reasonably available.
As always, suggestions and discussion is appreciated.
Old 03-06-2010
mmazour's Avatar
mmazour is on a distinguished road
Interlux Micron hands down
yachtpaint.com - the website of International and Interlux paints
Currently shopping for a Catalina 270 or 28
Old 03-06-2010
MC1 MC1 is offline
MC1 is on a distinguished road
If you're interested in an ablative paint . . . I'm using Interlux Micron Extra in Lake Ontario with great results. A lot of people are using Micron CSC here as well (less copper, a little cheaper) since the bio growth is not as agressive as in warmer waters. I touch up in the spring with a quart around the waterline, otherwise its working fine as a multi-year paint (I just powerwash it lightly to reactivate it after winter storage).
Old 03-06-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
if you don't know what's on it now, and don't want to sand the old stuff off, you might want to go with just bottomkote- it will apply over damn near everything.
http://www.yachtpaint.com/Images/15_27607.pdf
Old 03-08-2010
Sanduskysailor is on a distinguished road
A lot has to do with what is on there. VC-17 is the easiest to maintain with no buildup. A guy I work with had ablative paint on his boat since new (10 years). The buildup became a little rough over the years and he stripped it this winter. After recoating with VC 17 he wondered why he hadn't done it sooner. Lake Erie or Lake Ontario slime is the only real issue. Make sure whatever you use has a biocide like Ingarol or equivalent.
PS. Where is the boat on Lake Erie? Per chance is it a yellow Santana 27?
Old 03-08-2010
sailortjk1's Avatar
VC-17 is by far the most popular paint in my region. (Southern Lake Michigan)
Courtney is My Hero
Old 03-08-2010
kwaltersmi's Avatar
Broad Reachin'
kwaltersmi is on a distinguished road
My boat came with VC-17 and I've been keeping it that way. So far so good.
Old 03-08-2010
Great Lakes Sailor
padean is on a distinguished road
Petit SR21 working fine for 3 years in lake Huron.
PDean
CS 34
Saginaw Bay, Michigan
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails." - William Arthur Ward
Old 03-08-2010
Keldee is on a distinguished road
The only trouble with VC-17 is nothing else will go over it so if you want to change any time it has to be completely stripped off.This is what we had to do when we wanted to go in warmer water as VC is then hopeless.
Old 03-10-2010
fparry's Avatar
I found out from the previous owner that he had applied West Marine Bottom Shield to the boat. Does anyone here have any experience with this product? It is certainly less expensive than other products discussed. Any compatibility issues?
Great Lakes Bottom Paint? 1970Columbia34 Gear & Maintenance 10 02-12-2007 12:32 PM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Bottom Paint Compatibility Dan Dickison Gear and Maintenance Articles 0 01-24-2001 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
