bulging deck at chain plate cover - Page 2 - SailNet Community
post #11 of 14 Old 03-07-2010 Thread Starter
why didnt i think of that? thanks captain...I'll go down there tomorrow..
I dont want to think about what I'll do if its rotten..
acceri
long island sound
Pearson 10m 1974
acceri is offline
post #12 of 14 Old 03-10-2010 Thread Starter
good news.I think
I got caseys book..I removed a few bolts through the chainplate and bulkhear..They are dry and tight.. I need to find out if the deck is cored at this chainplate attachment location.When I remove the offending deck skin under the deck plate , if the deck is cored, I will remove core (a bit) beyond the dimention of the deck plate, fill with epoxy (remembering to seal the inside skin with a temp patch) sand and reinstall deck plate..If its not cored.....whats that mean? just the top skin (deck) and soekind of block or reinforcement under there? Since the deck is bulging a bit, I think I'll have to cut it out (somehow) and fill with epoxy as if it was cored...what do you think?
gene
acceri
long island sound
Pearson 10m 1974
acceri is offline
post #13 of 14 Old 03-10-2010
Check this site out. It seems that 10Ms have a chainplate problem. Pretty much explains what you need to do. Pearson 10M Chainplates
Good luck
Sanduskysailor is offline
post #14 of 14 Old 09-13-2010
Bali Hai
mgraham49's Avatar
Send a message via Skype™ to mgraham49
Did you solve the mystery of the bulging deck around the chain plate cover? What is your Hull number on your 10M? If it is less than hull 100 (and I suspect it is) then Pearson had an issue with the way in which the main chainplates were attached to the hull.
Since you haven't posted since March, I assume you worked it out?
mgraham49 is offline
Replaced chain plate deck core - Did I do something stupid? JeffBurright Gear & Maintenance 6 09-15-2009 06:24 AM
Deck filling cover chain HolidayRI Island Packet 0 08-29-2006 01:40 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 08:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 09:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 08:00 PM
