Old 03-06-2010
Crapaud is on a distinguished road
Backstay: One good, two great?
I am replacing the mast and rigging on a Pearson 26. With everything now coming together, my rigger asked me if I want to copy the old design of the Split Backstay or rig a Double Backstay?
The double backstay would reduce the number of terminals from 6 to 4, but it will also increase the weight of the backstay rigging. Are there any other pros & cons that I am missing? Any strong opinions either way?
Old 03-06-2010
Two backstays or double backstays aren't really necessary on most boats. I'd go with the single backstay with the y-plate and two termination points on deck or a split backstay. Then you can add a backstay adjuster to the rig to help with sail shape control.
Old 03-06-2010
tager's Avatar
tager is on a distinguished road
Pieces of String Too Short to Save
Brion Toss doesn't seem to like them. I know this is a genetic fallacy, but come on, it's Brion Toss!
Old 03-07-2010
paulk's Avatar
paulk is on a distinguished road
Good reasoning from Brion. Thanks for the link.
In answer to the poster's question, double backstays do seem like overkill. Added windage, added weight, and the forces involved aren't so big that dividing them between two stays would be necessary. Splitting the backstay is convenient if you access the boat via the transom. As suggested earlier, it also makes it easy to adjust backstay tension; it's the setup we have on our J/36. Having that much torquing power on a Pearson 26 might also be overkill however. It the mast is built like a telephone pole, cranking the backstay might simply work to push the it through the botttom of the boat while turning the hull into a banana. For the convenience of transom access, just make sure the opening is wide enough (and tall enough) to step through. If the transom isn't too wide, splitting the backstay might be more trouble than simply going past it on one side or the other. It sounds like the original setup (split) is the way to go. KISS.
Old 03-07-2010
Architeuthis is on a distinguished road
Originally Posted by paulk View Post
..forces involved aren't so big that dividing them between two stays would be necessary. Splitting the backstay is convenient if you access the boat via the transom. ...
Access to the transom is the only reason I can see. If we need two back stays then I figure we need two forestays.
Have faith that the oceans are going to rise and flood the world, that plague and pestilence brought on by Climate Change is going to punish us for not believing. Please do as they say it is our only hope. :P
Backstay Insulator for SSB trodzen Gear & Maintenance 31 03-25-2011 12:25 PM
Production blue water boats JakeLevi Boat Review and Purchase Forum 73 07-31-2009 10:07 PM
Great day, Bad Day Mick Young General Discussion (sailing related) 8 12-05-2006 01:24 AM
My Great Struggle CuriousGeorge Boat Review and Purchase Forum 5 02-24-2006 10:02 AM
Ingredients for a Good Leader John Rousmaniere Her Sailnet Articles 0 08-27-2001 08:00 PM
