03-07-2010
Stuck In-Boom Outhaul
I have recently bought a 1971 C&C 35 that appears to have an in-boom outhaul mechanism with a socket that receives a handle near the gooseneck on the starboard side. Not sure if this is original equipment, but it looks as old as everything else. I've tried turning the socket every which way and in combination with pulling, pushing and jiggling but can't make it budge in any direction. Currently, the outhaul has the foot of the main stretched very tight, too tight. I asked the prior owner about it, who acknowledged that it was tricky. Does anyone have any advice on what to try next? I have no idea how the mechanism is supposed to work, assuming its working fine. Presumably there must be some kind of way to move the handle to make it ratchet the outhaul tighter and some way to release the tension. Is there a typical movement of the handle that I should try? If it is busted, what's the best way to tell and explore what needs to be fixed? Remove and disassemble the boom? Thanks anyone and everyone with any advice.
