Old 03-08-2010
ArgleBargle is on a distinguished road
extra sacrificial zinc for saildrive
Hi
I use a galvanic isolator and have an extra zinc "fish" that is coupled to the the common ground on ye boate. no corrosion issues there.
i have yanmar ym30 with SD20 saildrive and flex-o-fold prop.
the saildrive appears to be electrically isolated from the common ground (which i assume is good to keep the aluminum leg from acting as a giant sacrificial anode for the rest of the boat).
i dont like how quickly the saildrive zinc corrodes, so i change it every 6-9 months.
does anyone think adding a second zinc "fish" coupled to the saildrive bolts from inside the hull and hung over the side would appreciably help anything/reduce rate of zinc usage? - i assume those bolts are electrically connected to the leg.
thanks
Old 03-09-2010
Plumbean is on a distinguished road
I have the same setup (YM30 and SD20). I assume you are aware that there is a second zinc (pencil style) on the port side of the saildrive unit (inside the boat)?
As to how quickly they are used up, so far my experience matches yours. Last season was the first, and we pretty much went through the exterior zinc in about 7 months. FYI, you can get a split version that can be changed underwater. I haven't climbed down into the bilge to check how the pencil style zinc fared yet (on my list for spring commissioning).
Can't answer your original question though (sorry).
Old 03-09-2010
Livia's Avatar
Vagabond in Training
Livia is on a distinguished road
We have a volvo saildrive and we use a zinc guppy on our sail drive bolts run out of the lazarette and over the side.
The guppy doesnt grow crud which we assume means it is working, but we've had the same zinc for 3 years. With that being said, we don't lose our sail drive zinc very quickly either.
A l'eau, c'est l'heure
s/v Estrellita 5.10b, Wauquiez Pretorien 35
Determining zinc use Mkfcdl Gear & Maintenance 3 08-21-2006 02:33 AM
Shaft Zinc FlySwat Gear & Maintenance 6 06-11-2005 04:15 PM
