Old 03-09-2010
Gene T's Avatar
Gene T is on a distinguished road
What's wrong with this picture
Working on my new boat and decided to put in a new impeller. Engine was pumping fine but just didn't know how long the old one had been in. This is what I found.
Currently in Long Beach, CA
Old 03-09-2010
zeehag's Avatar
zeehag is on a distinguished road
looks like it should look---if dont know age then change it out--they are inexpensive--and carry spares.....
Old 03-09-2010
Cabin boy
JimHawkins is on a distinguished road
What's all that build-up at the bottom?
Never listen to someone describe why your project will not work unless they can show you the broken pieces of their own version. - Robert Gainer
Old 03-09-2010
sailortjk1's Avatar
I'm surprised the blades are still intact.
Courtney is My Hero
Old 03-09-2010
k1vsk will become famous soon enough
It's almost irrelevant how old the existing one is as it cheap insurance and always a good idea to change it annually. Visually inspecting an old impeller can often be misleading as you can't see tears in the blades or a split or separation in the spline.
Old 03-09-2010
sailortjk1's Avatar
Guys, there is more going on here than a simple replacement of the impeller.
Look again at the picture.
Or is it just me?
I have never seen a housing that is oblong shaped.
Courtney is My Hero
Old 03-09-2010
buckeyesailor's Avatar
buckeyesailor is on a distinguished road
any chance it sat idle for a Loooong time?........looks like a deposit of some sort to me.........but I know nothing.
Poverty motivates me in ways prosperity never could.
(stolen from Eddie Jones)
Old 03-09-2010
That's totally normal, except that a couple of vanes seem to be bent the wrong way. The shoe at '8 oclock' in the pic is a normal part of the pump and is what ensures that water is forced out the outlet rather than circulate within the pump.
The vane reversal could have happened if the engine "kicked back" a bit when it stopped... Looks otherwise normal to me.
1984 Fast/Nicholson 345
Old 03-09-2010
jrd22's Avatar
Courtney the Dancer
I agree with Faster, the housing is supposed to have that built up area. Why there are vanes going opposite directions I'm not sure about. If the impeller was incorrectly installed in the first place, with some of the vanes going the wrong way, I suppose they could have stayed that way if it was a long time before it was run. Replace with all vanes going in the correct direction and it should be fine.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 03-09-2010
tip's Avatar
tip tip is offline
tip is on a distinguished road
Once the pump starts turning, the vanes will flip and run the correct direction.
The pump probably rotated a small bit the opposite way, causing a vane to flip.
Gene - I like the fact that you decided to replace it based on not knowing how old it is. I will be replacing mine soon, even though the previous owned said it was "like a year old".
-tip
Bellingham, WA
Let's see a picture of your Sailing Pet!!! Cruisingdad General Discussion (sailing related) 13 11-09-2009 12:05 PM
Newbie: What's wrong with this picture MaineCub Learning to Sail 21 01-07-2007 07:28 PM
;-) Oh yes, I forgot about that picture, thanks Ahmet .... NewsReader Mass Bay Sailors 0 05-04-2006 04:15 PM
Sam, picture problem again! nauticalrich General Discussion (sailing related) 0 03-13-2003 04:12 AM
