03-10-2010
there are different types of vinyl, and 2 types of the seafit type. go with the better one, its only a few dollars more and is much better vinyl and will last longer.
the eraser wheel is usually called a pin stripe remover, or vinyl zapper. there are a few brands/models. most offer it with a buffer or as a wheel that can be used on a buffer or electric drill. once off there are adhesive removers available but just remember as with paint prep is everything and you have to have the surface preped correctly for it to last.
side note: the two main types of vinyl are calendared and cast, cast is more expensive and lasts longer. just google it and you will find a wealth of information.
