04-15-2010
Pearson 303
Originally Posted by gershel
What's the trick for geting a a smooth curve? I replaced my 2" stripe a few years ago, and as careful as I tried to be, I still got some slight waves.
Marc
Doing the longest sections possible as you work along. I used to do car pinstripes years ago and there is a learning curve. I never used the soapy water method for stripes, but did when I put on our hull lettering and it would probably make it easier for someone new to the process.
As for my technique, it is hard to describe, but I basically stick down one end, wherever you want to start. I then keep the tape taught, being careful not to over stretch, and pull the backing paper for a good length (for me, probably six to seven feet at a time). Then, keeping the tape away from the hull (you don't want it to stick until you are ready), sight down the length of the material until it follows the lines you want. Then, slowly bring it to the hull for initial contact. To follow the hull lines, you will need to raise/lower the tape as it is coming in contact with the hull. The longer the lead section you work with, the straighter your lines, and it will better allow for graceful curves along the hull. I keep pulling the backing tape as I move along, so that there is always several feet of tape ready to stick. When you get to the end, stick it down longer than the point you want to stop, then trim with a fresh razorblade.
I hope this makes sense (much easier to show in person than to write-up.).
