Old 03-11-2010
Greenflash35's Avatar
Greenflash35 is on a distinguished road
Moisture Meters
There are so many Moisture Meters to choose from, we can't decide which one is best for a fiberglass boat. Any suggestions?
GreenFlash35
Old 03-11-2010
Capnblu is on a distinguished road
if you search for SailingDogs post I think he and Maine sail recommend the Electro physics brand
Why, why, why?
Old 03-11-2010
Read Maine Sail's excellent article on using them. You can find it HERE.
Old 03-11-2010
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
A capacitance-type unit is best. I have the Electrophysics CT-33
DO NOT use a resistance-type unit. These require inserting probes into the sample being tested. People may get upset if, when trying to determine the moisture content of fiberglass cored deck or hull, if you start drilling holes in their boat.
ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
Old 03-11-2010
Great info, Thanx for the help everyone.
GreenFlash35
Old 03-20-2010
RhythmDoctor's Avatar
RhythmDoctor will become famous soon enough
If you want direct, absolute moisture values that you can compare with a broad history of other boats, the CT-33 (or its American equivalent) is the only one to get because it's the one that all the professional surveyors use.
If you want to save some money and just be able to trace pathways of water intrusion in your decks, find studs in your home, etc., there are two low-cost pinless meters that I have tested.
This one, available at Home Depot online only for $90+shipping, was very unreliable (unrepeatable), and I would not suggest it:
General Tools Non-Invasive Digital Moisture Meter w/LCD Display - MMD5NP at The Home Depot
This one, available for $50 off the shelf from Home Depot, was very reliable and repeatable. However, in my side-by-side testing with a borrowed CT-33 its absolute values do not correlate directly, probably because its penetration depth is a little less:
Ryobi Accessories :: Pinless Moisture Meter
So for most people I would suggest spending the money for the CT-33. But the $50 Ryobi may work well enough for some people.
1998 Catalina 250WK "Take Five" (at Anchorage Marina, Essington, on the Delaware River)
1991 15' Trophy (Lake Wallenpaupack)
Old 03-21-2010
We ordered the Ct-33, Thank you Sailnetters.
GreenFlash35
Could I borrow a moisture meter? RhythmDoctor Boat Review and Purchase Forum 1 12-21-2009 08:48 AM
Moisture meters svs3 Gear & Maintenance 1 01-02-2007 04:25 AM
Buying Boat in Winter Sailormon6 Boat Review and Purchase Forum 16 01-19-2005 02:01 AM
Using Moisture Meters Dan Dickison Gear and Maintenance Articles 0 03-03-2002 07:00 PM
Hull moisture MIKEHARTMN Boat Review and Purchase Forum 4 05-25-2001 05:35 PM
