Old 03-11-2010
zephyrhas is on a distinguished road
slow leak in Merit 25
My boat is docked in a lake that is not a constant level. because of drought conditions that started 1-1/2 yrs ago, my Merit 25 was high and dry on its keel and port side during that time. (I was unable to move it ahead of the drought because of serious illness). we now have water in the lake and the boat has a slow leak. any ideas on what it likely is and how i might rectify this?
Old 03-11-2010
roline's Avatar
Cal 9.2 SilverSwan
roline is on a distinguished road
It is my understanding that the Merit 25 has a keel attachment issue. I took a look at one on Lake Norman many yrs ago. The keel had movement when hung in a cradle. If yours also has a less than desirable keel attachment, this could be your problem and require reattachment and sealing. There are many Merits in the SF bay, perhaps some of the local full service marinas could give you advice on this subject.
Cal 9.2 #19 SilverSwan
Old 03-11-2010
i think roline is correct, especially given that your boat was resting on its side, putting a good deal of lateral stress on the hull-keel join.
Old 03-11-2010
zz4gta's Avatar
I don't discuss my member
zz4gta is on a distinguished road
First, determine were the leak is coming from. Windows, through hulls, hatches, all leak.
Second, if it does turn out to be the horrible "keel wobble" then you have delamination issues if the water is getting inside the boat through the hull. The stringers weren't built strong enough to give much lateral support. Check out skedaddle yacht club, it has many pictures about the repair and links to the Merit 25 home page, which hasn't been updated in over a decade. But the skedaddle site is alive and well.
Get the boat hauled in a travel lift and check the keel for wiggle or wobble after you make sure you've ruled out everything else.
Merit 25 # 764 "Audrey"
Merit 25 OD racing wddesign2000 General Discussion (sailing related) 3 03-03-2009 01:26 PM
Merit OD racing wddesign2000 Racing 1 01-19-2007 06:03 PM
Yanmar Fuel Leak jnj Gear & Maintenance 3 07-19-2005 12:41 AM
Universal m35 leak at drain plug sailingdeacon Gear & Maintenance 1 01-07-2005 11:21 AM
The Dreaded Keel Bolt Leak Mark Matthews Gear and Maintenance Articles 0 04-07-2002 08:00 PM
