Old 03-11-2010
krozet's Avatar
Waiting For Spring
krozet is on a distinguished road
Depth Gauge or Fish Finder...
Hello Again;
The Depth Gauge on my boat is toast and I am looking at a replacement. I thought the easiest way of repairing it would be to use a fish finder. I can borrow a fish finder off my father in law to get the boat back to Canada then worry about figuring out if the transducer is bad or the gauge or whatever.
Would it just make more sense to replace the unit now as the boat is out of the water than to fiddle with a fish finder and then replace the unit next year when I haul out the boat to do the bottom paint?
Maybe I am trying to take the easy way out on a few things and this is something I should just take the time to fix now.
Thanks all;
Robert
1971 Contest 33 Hull Number 24
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."
Mark Twain
Old 03-12-2010
Why not just replace the depthsounder. It would help if you said what kind of boat you had in your signature or include it in the post. If the boat has a solid glass hull, you can install a new depthsounder without installing a new through-hull, since most modern depth transducers can easily shoot through a solid glass hull.
One way to do this installation is to set the transducer on a ziploc bag full of water. Move it around until you find a spot where it gives a good reading.
Mark the spot on the hull and then fiberglass in a 4" PVC schedule 80 clean out fitting to the hull there.
Cut a hole in the clean out fitting cap and mount the transducer in the cap. Fill the cleanout with mineral oil or non-toxic antifreeze.
Screw the cap into place.
Old 03-12-2010
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
I reccomend the FIsh FInder. The advantage of these units is that with the graphical output, you can see the trend of the bottom (and fish or course) and by adjusting the gain you can also get a fairly good idea of bottom conditions--e.g. a sharp return indicates a hard bottom, a sharp return under a fuzzy upper layer a hard bottom under mud or grass, etc.
FWIW...
Old 03-12-2010
krozet's Avatar
Waiting For Spring
FWIW...
Hey;
Yeah the fish finder is brand new and free so i might as well take it. I should probably install a new depth finder as well since I will be working on the boat anyway.
Thanks for the info;
Robert
Mark Twain
Old 03-12-2010
marianclaire is on a distinguished road
Just a fish finder story. The 35 year old depth sounder on the MC crapped out on one of my trips south. No way to access it with out pulling the mast. I bought a 100+- $ transom mounted unit from WM. The tranducer would not send thru the thick wood hull so I installed it on the aft edge of the rudder and it worked. A few limitations: the reading is aft of the low point of the full keel and any thing above 2000 RPM and the prop wash disrupted the signal. I have improved the location off the rudder but the unit is the same after three years. IT WORKS. Dan S/V Marian Claire
Old 03-12-2010
Seafire327's Avatar
Seafire327 is on a distinguished road
Is the mineral oil a dampener of some sort?
'70 Columbia C26 Mk II - "Klydo"
Boston, Ma
Old 03-12-2010
No, the mineral oil or non-toxic antifreeze transmit the sound waves from the transducer to the hull without allowing bubbles to form.
Depth Gauge vs. Fishfinder larsfis Gear & Maintenance 2 02-16-2003 06:27 PM
Fishing for Sailors SailNet Her Sailnet Articles 0 09-15-2001 08:00 PM
