Old 03-12-2010
QuickMick's Avatar
QuickMick is on a distinguished road
boom vang set up
the P.O with the BO rigged the boom vang to the little step protruding from the companion way slats. I couldnt imagine it being in a more inconvienient place, especially as it allow water to collect in the created channel.
I am thinking about moving it toward the bow and mounting it atop the main cabin. has anyone done this/have any pointers? should i be concerned about moving the pulleys as well to keep the same distance from said cockamamie set up?
thanks
Quinn
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 03-12-2010
Without photos, it is hard to say...but the cabin top sounds like a much better location. The boom vang should ideally go back to the mast base or very close to that point in order to function properly.
Old 03-12-2010
ASA and PSIA Instructor
Ditto whaty SD said. The vang MUST terminate at the base of the mast, or whenver you trim th emainshet you;ll need to also adjust the vang. Seems lijke that would be a pain.
I'd bet there's been some confusions omewhere along the line, and if you look around th emast collar, you;ll see a spot for connecting the vang
Old 03-13-2010
mitiempo's Avatar
I think he might be talking about his mainsheet.
Brian
Old 03-13-2010
If he doesn't know the difference between a mainsheet and a boom vang, the OP has some other, far more serious issues to deal with....
Old 03-13-2010
mitiempo's Avatar
So does someone with their vang attached to the little step protruding from the companionway slats. I think he means the bridge deck. Quinn, posting pics really helps with this kind of question.
Brian
Old 03-13-2010
I can't see anyone ever installing a boomvang to the bridgedeck. That pretty much destroys the full utility of the boom vang.
Old 03-13-2010
QuickMick's Avatar
I'll take pics today and post 'em monday. While the inmates may be running the asylum, you guys are a plethora of knowledge. thanks much
Quinn McColly
Yacht Broker
Old 03-13-2010
QuickMick's Avatar
Wink btw dog
it's one thing to bust a guys chops who thinks he knows everything, its another thing entirely to bust a guys chops who is big enough to be small enough to admit what he doesn't know and try to learn.
regards
Q
Quinn McColly
Yacht Broker
Old 03-13-2010
Mick—
Wasn't busting your chops... I was making a very serious point—if you don't know the difference between a boom vang and a mainsheet—you're really going to have a steep learning curve.
Besides, I wasn't the one questioning you... Mitiemp was.
BTW, his questioning is valid, as it makes no sense to mount a boomvang to the companionway, as that effectively kills its utility. However, it is fairly common for mid-boom mainsheet setups to be terminated near there.
Without photos, can't really know what is really going on.
regards
Q
Deadly Serious about Booms John Rousmaniere Seamanship Articles 0 10-12-2004 08:00 PM
Boom Vangs SailNet Racing Articles 0 10-04-2000 08:00 PM
