Old 03-12-2010
prior's Avatar
prior is on a distinguished road
Question Tinned Marine Wire
I am installing a windlass and other major electrical renovation on my CS 36T. I have come across Tinned Marine Wire as a potential cable supplier. Their prices seem very good, particularly with shippping north of the 49th.
Has anyone used their wire?
Thanks
Old 03-13-2010
mitiempo's Avatar
I haven't used their wire but it looks fine. Genuinedealz.com has very good prices as well and ships to Canada. They also do excellent crimps for $1.00 each which is hard to beat unless you have a good crimper. Make sure you use a heavy enough cable. Many windlass manufacturers recommend too small a cable for good performance - Lewmar being one. Here's a good link for the calcs. Just fill in the blanks a to get the answer. Best to go with 3% or less voltage drop. AWG by wire length/amps calculator
Also check out this site - Maine sail also has a CS36T
Compass Marine Project Articles Photo Gallery by Compass Marine at pbase.com
Brian
Old 03-13-2010
r.furborough is on a distinguished road
I've purchased from Genuindealz.com, they generally supply Pacer branded cable, it's good cable.
Old 03-13-2010
Maine Sail's Avatar
I would call them to ascertain the brand of wire. Of the four big ones I prefer them in the order below (not including cost here, just workability and construction quality). I really dislike Cobra wire. It is stiff and becomes very difficult to work with in cold temps. The Berkshire is flexible and easy to work even in sub freezing temps. The Cobra jacketing also seems to get brittle quickly? Top quality builders like Morris Yachts & Lyman Morse use Berkshire.
Battery World in Portland, ME will ship it but you need to buy 100 ft min spools.
Genuine Dealz is very good and sells Pacer.
Sailors Solutions sells Berkshire too..
My preference order
Berkshire Wire
Ancor
Pacer
Cobra
______
-Maine Sail / CS-36T
Old 03-13-2010
I'd second using Berkshire wire, though I buy from a different source than Maine Sail. The stuff is very flexible, and very high quality.
Old 03-13-2010
prior's Avatar
I am planning to go with AWG 2 for the windlass based on a reportedly fine (by some)10% voltage drop. I may install a battery in the bow as well but am undecided. I am thinking the windlass will run at about 85 amps under normal load?
130 amp, 50’. @ 10%
10.75x130x50/1.2=58229 AWG2
CM=K x l x L / E
CM = Circular Mil area of Conductors
K = 10.75 (Constant representing the mil-foot resistance of copper)
I = Current - amps
L = Length - feet
E = Voltage drop at load (in volts)
Old 03-13-2010
mitiempo's Avatar
I'd go heavier and aim for 3% drop. Better performance as well as longer life for the windlass motor. That translates to 4/0. The area of 4/0 is over 3 times the area of awg 2. I'd at least go to 2/0.
I'd skip putting a battery forward as this would complicate your charging and better in my opinion to put the money into larger wire than charging devices. Besides a battery under the V-berth isn't a great idea I don't think.
Maine sail - opinion please.
Brian
Old 03-13-2010
tager's Avatar
tager is on a distinguished road
It makes more sense to put another battery in the bow, then you have almost zero voltage drop.
Old 03-13-2010
For a windlass, you really don't want a 10% voltage drop. It would probably make far more sense to install a battery forward and use a duocharge unit to keep it charged or to go with much heavier wire to provide a 3% voltage drop at a maximum. Providing low voltage to a windlass motor will shorten its lifespan.
BTW, from the lewmar windlass instructions:
Check the voltage across the motor leads with the windlass on. (Proper voltage is 13.5 V. Constant low voltage will destroy the motor)
130 amp, 50’. @ 10%
CM=K x l x L / E
I = Current - amps
L = Length - feet
Old 03-13-2010
mitiempo's Avatar
I disagree. In addition to the battery placement forward you won't save on cable. If you use an ACR the forward and main batteries will be paralled during charging therefore requiring a large cable as well. The Duo charge maxes out at 30 amps so you will still need 2 awg wire to maintain a 3% drop if you use one of these. If you were to use an Echocharge it would charge the forward battery with a maximum of 15 amps of current so the cable can be 6 awg for 3% drop. But by the time you buy the ACR, Duocharge, or Echocharge and glass in a tray for the battery with hold down straps as you should you might as well buy the heavier cable. It's easier and all you have to buy is the cable and a fuse to install in the line near the battery. And no battery to maintain and fit forward.
Brian
Keeping Wiring Woes at Bay Chris Brignoli Gear and Maintenance Articles 0 01-26-2004 07:00 PM
Electrical Work Rules Don Casey Gear and Maintenance Articles 0 07-16-2000 08:00 PM
