03-12-2010
I would reverse this.. and do the glassing over from the outside and plugt the inside.... If there were a problem with the patch... the water pressure would be far more likely to hold it in place this way, rather than pop it out...
Originally Posted by brak
 Sailingdog's method is a Bible of doing this.
In a pinch, however, for relatively small holes you can simply glass it over from inside with a layer or two of glass roving/cloth, then fill the hole from outside with epoxy mixed with filler. This construction is certainly no less strong than the thru-hull that was previously in that hole.
